Can I run 4 gauge? Or do I need 0 gauge?
Old 04-03-07, 05:39 PM
  #31
MJHSC400
MJHSC400's Avatar
Here's an MTX 1000d -- Bidding is at $150 -- Birthsheet says 1200w @ 12.5v -- So at 15~16v it'll make closer to 1400w -- http://cgi.ebay.com/MTX-THUNDER-1000...QQcmdZViewItem
Old 04-03-07, 05:41 PM
  #32
MJHSC400
MJHSC400's Avatar
And my favorite-- A 1500dx -- 1000w rms @ 2ohm -- $200 buy it now-- But get him to send you pics first-- http://cgi.ebay.com/mtx-thunder-1500...QQcmdZViewItem
Old 04-04-07, 10:50 AM
  #33
golfkid777
golfkid777's Avatar
I am definately going to be getting rid of my Subs and going with a TC-2000 or TC-3000 single 12.
Old 04-04-07, 03:11 PM
  #34
MJHSC400
MJHSC400's Avatar
sweet-- you won't be disappointed whether you get a single 2000 or a pair of 1000's -- Either will pound-- a pair of 1000's will have the edge on overall output and efficiency, and the single 2000 will have the edge on a little better sound q, while being one of the top woofers on the market today--
If you get a 2000, get a single 4ohm, a pair of 1000's need to be the dual 4 voice coil model -- either will match your amp well--
So in short, if you want to inflict pain on innocent bystanders and lose your hearing quickly while sounding good-- get the pair of 1000's, and if you want the utmost of SQL, SQ + SPL, get the 2000-- as it's a no compromise SQL woofer-- Sound quality of a Kappa Perfect, Image Dynamics, or Dynaudio sub, with the output of a CV stroker-- either one sounds good to me--
The 3000 is only in a 15 or an 18 -- I wouldn't mess with one of those unless you had an suv and were absolutely crazy-- The 3000 also won't match your amp in ohm load--
Old 04-04-07, 04:08 PM
  #35
golfkid777
golfkid777's Avatar
Alright, so i am almost convinced to go with the TC2000, if it is not enough, I will get 2 TC1000's later on a just build a new box. I am hoping I wont have this problem.
Old 04-04-07, 04:23 PM
  #36
MJHSC400
MJHSC400's Avatar
Just wait til you hear that 2000 -- nearly 30mm xmax?? Forgettaboutit --
The only problem you'll have is hearing damage--
Old 04-19-07, 02:36 PM
  #37
#1gs300
#1gs300's Avatar
Hello
If i were u i would get a 180amp alternator, and if u have a gs300, or a 400 idle on the engine usually runs 500 to 600rpm's get a 1 5/8" pulley on the alternator get 1 yellow top under the hood, and 2, or 3 yellow in the trunk, run 1,or 2 runs of 0 guage wire to the battery's in the trunk, and get 2 guage max to ur amps (if the batteries are in the trunk u dont need 0 guage to ur amps 2 guage is fine, 4 guage maybe iffy especally on class ab amps, its better to get a class d amp it doesnt require huge amounts of power to make power). U should be fine.
Old 04-20-07, 11:23 AM
  #38
MJHSC400
MJHSC400's Avatar
dude got a 6500d -- ~ 500w rms -- class D -- no need for all that --
Lexi66
ES - 5th Gen (2007-2012)
04-28-14 01:38 PM
Cioffdaddy
01-24-09 09:34 PM
jefthim
06-21-07 08:33 PM
chrispy
04-01-07 11:51 AM
JSnake916
12-26-03 03:21 PM
Quick Reply: Can I run 4 gauge? Or do I need 0 gauge?
