Subwoofer Replacing The Stock
Old 04-11-07, 01:41 PM
SC30096
SC30096's Avatar
Default Subwoofer Replacing The Stock
was wondering what would be the best setup including amplifier that would fit into the stock location without clearance issues.
thanks
Old 04-11-07, 02:58 PM
o2GS43o
o2GS43o's Avatar
You want to run a sub in the stock location tied into a aftermarket amp? You would need to find a Free Air subwoofer in which there are some but not a lot...
Old 04-11-07, 11:06 PM
AM1
AM1's Avatar
better off just getting a small sealed box. free air subs are not easy to find and if you do find one you might have to modify it to fit your stock location
Old 04-12-07, 05:09 AM
MJHSC400
MJHSC400's Avatar
Old 04-12-07, 05:52 AM
Robert_J
Robert_J's Avatar
That's right. Not all add the marketing label (that's all it is) of "free air" or "infinite baffle" or "IB" to their subs but many will work in that application. The sub that MJHSC400 links to is just one of many examples. It wouldn't be my first pick due to the Qts of .29 and the xmax of 9mm (both are too low for me) but that doesn't mean it won't sound great if installed properly.
-Robert
Old 04-12-07, 08:48 AM
MJHSC400
MJHSC400's Avatar
A higher xmax and power handling would be great, but those generally come with a larger magnet/motor structure that may or may not fit --
The old Cerwin Vega Stealth woofers were one of the best you could use for this app. --
JBL makes a pretty slim sub if I remember correctly that may be better than the one I listed above--
BUT-- you have room enough to build an enclosure with the ED slim sub above-- which will put it back on top compared to many other better subs running IB--
The JBL GTO looks slim-- 4 13/16" depth
The Clarion Slim sub can be had for about $70-- a deal by any measure -- AND a slim 3" top-mount depth
Old 04-13-07, 11:32 AM
SC30096
SC30096's Avatar
I googled this.... would it work?
https://www.clublexus.com/forums/sho...d.php?t=182902
let me know what you guys think
Old 04-13-07, 12:15 PM
Robert_J
Robert_J's Avatar
If you want a full sized sub (not a shallow mount) then it will work. There are also hundreds of others that will work as well. My favorite based on specs and reputation is the TC7.
-Robert
Old 04-15-07, 03:05 PM
MJHSC400
MJHSC400's Avatar
Crazy Idea-- What about running 3 6.5" subs across the rear deck???? On a single amp-- should be accurate--
11.5mm xmax -- 4ohm Tang Band subs-- 6.5" --
Old 04-15-07, 04:24 PM
MJHSC400
MJHSC400's Avatar
Or running 3 ED 10's across the rear deck -- and the right and left sides just being bottom mounted-- where the factory grilles remain intact--
Then use a fiberglass tub enclosure mocked up from mesh made to fit around the tank ---- That would be tight, clean, and most likely it would absolutely pound from being semi-horn loaded coupled with the rear glass like a hatch--
Now that's an idea I like-- Even IB would sound good -- or awesome-- probably a better word--
Old 04-15-07, 04:35 PM
MJHSC400
MJHSC400's Avatar
Or 3 of these beautie's -- ED 7kv.2-- 7" subwoofer -- 4 at a discount of $60 each-- Use the 4th to build a multimedia sub-- and mount the other 3 in the rear deck , use dual 4's and run a 2.7 ohm load-- give them 250w each-- -- sealed f-glass enclosure--
They have a 3.5" depth-- so I think they can be made to fit the center cutout by adding a ring that sits higher than the level of the deck-- which allows for the enclosure to clear -- if you decide to use one--
Old 04-18-07, 09:57 AM
XSTeknique
XSTeknique's Avatar
How does having a subwoofer in the trunk compare to the stock free-air in the car in terms of a clean, non-rattling sound? I don't listen to much bass, although I like the full sound of having a subwoofer.
Old 04-18-07, 10:56 AM
kaifiji
kaifiji's Avatar
anyone tried this...pretty low profile, plus they come in 10"
http://shopping.yahoo.com/p:Pioneer%...ker:1994454469
Old 04-18-07, 06:49 PM
MJHSC400
MJHSC400's Avatar
The reviews werent that great on Pioneers slim subs-- the ED sub is so slim you could fit an enclosure behind it even in the stock location with the appropriate volume--
You could realistically fit three in the rear deck to be honest-- Replacing the left and right grilles with larger grilles may be necessary, but the holes would only need to be large enough to accomodate the air movement from the cone alone-- so only about 7" in diameter-- which I'm pretty sure would fit the stock grilles-- and the center sub would be slim enough to fit without issues--
You'd have 1050 cm^2 cone area-- More than a single 15" sub in the rear deck--
My single 12 in the trunk doesn't rattle that bad-- but I haven't done anything to stop the rattling that is there-- since it's not that bad until it really starts pounding-- which it does do-- I just haven't had the time, but I'm confident it can be rattle free pretty easily--
Old 04-18-07, 07:34 PM
boostedny
boostedny's Avatar
would you guys suggest focal 10" to fit the stick location..anyone ever heard one..
Im looking for very clear crispy bass..I dont need tons of wattage
Quick Reply: Subwoofer Replacing The Stock
