I Cant Hear Anything
so when i put the key into the ignition and turn it to the first click... the radio comes on but there is barely any sound... even when I crank it to max I can hear a slight whisper...its only when I turn to the second click that everything is normal... does anyone know the problem? is it a crossed wire of some sort or is that how it usually is?
thanks
thanks
Mine works in the "On" or "Acc" position--
Sounds wierd-- maybe a bad connection somewhere in the harness--
My SC had some pretty badly corroded wiring under the backseat to the point that I had to eliminate a 17 connector plug altogether and butt-splice every single wire back together--
scampbell
08-26-12 06:15 PM
