Problem With Memory Settings for Seat, Mirrors, et al
![Post](https://www.clublexus.com/forums/images/icons/icon1.gif)
My memory settings (located on the driver's door) for the seat, mirrors and steering wheel are not working. I closely followed the instructions in the manual(ignition in "on" position, car not running, holding the "set" and "1" or "2" button simultaneously, etc.) but to no avail. When I push either button nothing happens. Does anyone know what I should check first in diagnosing the problem? Is there a common problem with this system which may be easily corrected. I would appreciate any insight.
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
hi terry,
I had similar problem when I got my car.
When I open the door panel, memory seat plug was not attached.?? and I pluged in and it's worknig..
I even asked dealer to look at it, they didn't even fix this ????
Power mirror, I probably need to change the ECU.
but I heard from dealer that Memory seat and power side mirror is somewhat related. but I'm not sure.
I dont know about steering wheel.
let me know if you solve your problem.
Terry - Mine doesn't work unless the foot brake's depressed & all the other parameters U mentioned are addressed. Not sure that's in the owner's manual - wife's got the car right now. Also seems to work better for me if I depress the "Set" button before the numbered button of choice even though the manual says differently. Might try these methods & then proceed to the dealership if all else fails. Good luck!
Da Hapa
09-30-06 03:52 PM
05, 330, doesnt, is350, lexus, memory, mirrors, problem, problemsetting, seat, seatsteering, stopped, wheelmirrors, work, working
