Have some general audio questions, have searched.
Hello
I own a 1996 LS400 with the stock pioneer system and frankly, it blows. My old car was a Dodge SRT-4 with the STOCK system and an aftermarket head unit and it blows this crap out of the water (didn't even have a sub).
ANYWAY
So i'm not looking to develop any "crazy" system. Just something that equals my old stock one. However i do want to install a AVIC-D3.
Now, from what i've read the stock amp won't work with aftermarket units right? So you need to bypass it correct? But then obviously it really isn't going to sound too well.
So what am i do here? Replace all the speakers, head unit, and buy a new amp? Or is there a cheaper solution? Again i'm not looking to go crazy. Just something equal to my old one. Also i'm not worried about the stock CD changer since i'll be using the integrated IPOD controls and will also just hookup my Zune to it. So no need for the CD changer.
Thanks again
ANYWAY
Thanks again
I installed an aftermarket stereo in my car and I had to bypass the amps. What I did was run new wires all the way to the rear speakers, and ran wires to the plug by the kick panels and tapped into the stock speaker wires for the doors. No need to run the wires to the door speakers themselves.
I am still using stock speakers, but I upgraded my subwoofer by buying an aftermarket amp and subwoofer in box.
Overall I think my sound system sounds pretty good without the use of factory amps.
So maybe i should start with the following:
1) The head unit i want to purchase
2) A new sub
3) Get a better amp
Then keep all the stock speakers and decide after that.
What do you think?
thanks
2) A new sub
3) Get a better amp
What do you think?
thanks
For the speakers, I just tapped the plug at the amp under the passenger seat.
You can use the factory amps with an aftermarket head unit-- you just have to be creative and able to read a wiring diagram--
The factory amps operate on low level signals just like aftermarket amps do.
I'm running my aftermarket amps on a factory head unit so I can't see why it wouldn't work the other way around.
Naah-- I was thinking you wouldn't be using the amp in your head unit-- But, on second thought it may be more powerful depending on what kind of head unit it is--
I was merely stating that you could use the factory amps with an aftermarket head unit--
It MAY really wake the factory amps up running them a stronger preamp signal, as the 92 Pioneer head unit has a pretty weak preamp signal-- your new one will be at least 2wice the oem preamp power--
DoritoDan
01-26-17 06:44 AM
TeamAM
12
08-09-07 10:23 AM
C to the O
04-05-05 08:08 AM
vondy21
05-22-03 03:02 AM
