aftermarket radio, stock antenna...help?
hey guys, i have this '94 es300 with an aftermarket radio in it. how do i get the motor connected so that the antenna goes up and down, and more importantly how can i get it so that i can put in a new mast?
You need to hook up the blue wire to the antenna wire. If there is a harness just match the wires. If not hook the blue wire from the radio to the light green with red stripe on the car.
Once you get the power antenna hooked up you should be able to replace your mast provided the motor works or the mast isn't broken in half down in the power unit.
Alphaman19
03-04-14 09:30 PM
