Stock sub isn't working
every other speaker in the my sc300 has sound coming from it except for my 10" subwoofer
Im planning on upgrading the stock later on but as a temporary I would like my stock to work. so what would be the first diagnosis for the problem??
is there a sub fuse? or an amp fuse located somewhere?
thanks for the help in advance
Mine was dead too--
I didn't bother troubleshooting the problem as I removed it completely and reglued the ring in place for the grille brackets to remain intact and to remain the foam ring on the top to reduce rattling--
BUT-- I would probe the power wire -- you need to remove the rear deck cover which requires removing the sub grille first-- then the whole rear seat-- Hint: To remove the sub grille-- simply pull up on the front edge fairly hard-- the rear brackets slide out after the front clips are pulled up-- really easy to do --
Then you can get to the wiring to the sub amp --
Use this diagram--
http://www.intellexual.net/faq/lexusstereo.swf
SC400 Stereo Wiring Diagram
Use this diagram--
DJ TANTRA
09-14-07 01:33 PM
HighSoarer
26
06-13-07 08:39 AM
