SC400 Balanced system
I looked, but, maybe not hard enough for the stock Naka's wattage. Are the fronts and rears the same in wattage? And is the stock speakers considered crappy because of that reason? Or is it the stock setup itself just bad and that's why everything else is just bad? Call me crazy, but, I happened to like my stock system, at least the mids. Ever since I "upgraded" them it just doesn't sound as good. According to some suggestions on the boards, I think my fronts are the problem to SQ. They are 4" Diamond Audio coaxials, and they get drowned out by the rears, which are also 4" Diamond Audio coaxials. I've been told that I need to get larger fronts - 6 1/2" and also make sure they're components. But, by enlarging the fronts, how will this affect my rears now? Should I keep the rears the same size or should I enlarge them to match the fronts to produce an equal distribution of sound?
I am assuming you are still using the Nak amp to power the new setup. That would be problem #1. Your speakers want more power.
#2 - I would not consider Diamond Audio to be a higher end speaker. IMO they are a low end speaker and the original Nak's performed better (when trhey were new).
The Nak amp has equal output of power to the fronts and rears (forget how much offhand).
I agree with Robert J to an extent. The rears are fill, but I do not agree that they are not needed at all. Rear mid range and high's are always needed for proper staging and imaging. Without them you will always "see" the music from the front and never as a surround.
Upgrade your amp first. If not satisfied, upgrade the speakers. Cost effective solutions are out there if $$ is a concern.
I was able to outfit my SC with MB Quart seperates and a JL Audio 10" sub for less than $400.
-Robert
I didn't mean to sound offensive. If I did I apologize.
I wasn't referring to "surround sound". I was referring to proper fill. It is necessary to have rear fill to properly "view" the sound in front of you.
Although mid & high range frequencies are directional, the absence of rear fill focuses the imaging directly in front of you as opposed to allowing the sound to "move" as it was recorded.
If you are looking for suggestions...
1) Replace your stock amp. I also think the stock speakers had a pretty decent quality sound, but I believe that the speakers, amp, and head unit all were designed to work together as a package.
2) Lose the rear speakers. Fill in a car should be mids to lows not highs. That being said I found that just my sub created the fill that was need for our cars.
3) If you decide to replace your front speakers then go with some good quality 4" separates like FOCAL 100KPs. Our cars cars came with very well sealed and well damped doors. The same set of speakers will sound different in your door as it will in the rear deck. I tried two different sets of 6.5s in the doors and they didn't sound anything like the were supposed to. The midbass was incredible, but the midbass and midvoice would muddle or drown out other sounds. I didnt try 5.25s...they might be better balanced.
My end result was...
Kenwood headunit, 4" Kicker Coaxial doors, factory sub, RF Punch 450.4. 2 channels for the fronts and the other two bridged to the sub. This setup was the best sounding for imaging and the best for the $$. The fronts have plenty of power and are clear and powerful. The sub sounds ok depending on the music, but it is still limited by free-air, impedance, and it inablility to handle all the power that my amp has. I only have the gain turned up about half way for the fronts and the sub. I hope some of my experince helps.
Good luck dude!
Good luck dude!
The Diamonds are fine ---
The factory's are even better if used in the orig. enclosure-- BUT- you may use a better tweet with an outboard or hand built crossover for them--
The amp should be upgraded for sure-- and ANY speaker will be much quieter or louder and/or have a much different response when played freeair reflecting directly off glass vs. playing in an enclosure not even designed for them and firing through a very oddly shaped hole that blocks a good deal of the on-axis (front center) sound from the speaker itself--
No need to apologize. I just think we have different opinions on how things should sound.
I've played with rear fill and no-rear fill and I like none. I've run my cars like this all the way back to my '87 CRX. This past weekend, I had people in the back of our ES-350 so I adjusted the radio for "all passengers". I could hear the back speakers and I didn't like it.
I want the image focused directly in front of me. It should be like going to a concert where all of the sound is coming from the stage.
Don't get me wrong, I don't want it to sound like there's a single mono speaker in the middle of the dash. A quality recording on a good system will use stereo separation and phase to give the sound a wide "sound stage". The sub should be crossed over low enough so it doesn't sound like it is in the trunk. It should blend seamlessly into the mids and and they all should cover the frequency range of all of the instruments being listened to.
-Robert
-Robert
Guys, my apologies. I failed to mention that this system is hooked up with an Aftermarket Amp (Phoenix Gold 5.0;4). I just glanced over the posts real quick to get a general consensus. I'm going to reread it again later when I have more time. Thanks for the responses though.
-Robert
-Robert
Good luck dude!
Good luck dude!
Best Buy is not a place to go to sample quality speakers. Did you listen to coaxials or components? A good set of component 6.5" mids/tweeters from CDT, DLS or ED should sound incredible compared to anything from BB. From what I've heard, even the component set from the Cadence Audio outlet site is a steal compared to the sound you get from it.
-Robert
-Robert
-Robert
-Robert
