defective channel in multi-channel amp
anybody know where i can get an Alpine MRD-F752 amp from. it suits my need. and am guessing it won't be too expensive since is an old model
here are the specs
5 Channel class T Amplifier
RMS power Channels 1-4 at 12V, 20Hz ∼ 20kHz:
4 x 75W @ 4 ohms (0.08% THD)
4 x 100W @ 2 ohms (0.3% THD)
2 x 200W @ 4 ohms bridge (0.3% THD)
RMS power Channel 5 at 12V, 20Hz ∼ 20kHz:
1 x 250W @ 4 ohms (12V - 0.3% THD)
Freq. Response: 20Hz ∼ 20kHz (+0,-1dB)
S/N Ratio: 100dBA (at rated power)
Fuse: 80A
Dimensions: 17.9" x 10.2" x 2.4" (46cm x 26cm x 6cm)
Weight: 18.5 lb. (8.4 kg.)
Manufactured in 1999-2002
here are the specs
Fuse: 80A
I recall that you were wanting to run 2 4ohm subs, in which case you'd need a different amp-- the sub channel on that alpine only does 4ohm loads--
The PPI is MUCH MUCH MUCH better-- Just to let you know-- I'd jump on it while you can-- you won't find that amp for sale often and especially not in mint condition--
$350 shipped is very fair for that level of quality equipment--
It might just last longer than your car--
$325 shipped is not a lot of money for this level of quality --
The seller has 710 transactions with 98.8% positive, accepts returns, and it qualifies for paypal buyer protection--
Moderator - Electronics Forum
Not surprised that Alpine had a channel drop. I used to have a MRVF300 that had two out of the four channels DEAD out of the box. Upgraded to the MRVF400 on the spot and then later sold it to a buddy. Then upgraded to McIntosh. You can't get any higher than that for sound quality. ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Percy
Percy
almeshtaq
04-25-19 10:35 AM
