SC400 - MDF template - Mounting 6 1/2 Fronts
Alright, I got ya now. I'm gonna go digging for the stock sets now, if I still have them. I have to admit, I was most happiest with the original setup before I modified anything. If I remember correctly though, I may have blown both the front and rear stocks back then - making them only playable at mid-level volume. Let me also look into the comp sets you recommended. Thanks as always, MJ.
MJSC400, 88supramki, or anyone else that thinks they can help me:
Is there anyway I can contact you guys about this installation beyond the forums? AIM?
I have also talked with Focal techs about this exact situation because I wanted to build little enclosures for my Utopias, mainly to keep them from being exposed to the elements. I was told that their mid range speakers were not designed for that and that I would get much better quality sound out of the free air scenario. I can give you the number to Focal to ask if you like seeing as I deal with them on a daily basis.
Seriously-- IB alignments ALWAYS roll off earlier than a sealed or ported, but especially ported--
IB's claim to fame is musicality, faster attack, and better sq because of that, BUT, it decreases power handling and cone control in the lower frequencies--
I doubt the 5.25's you were using were in the proper sized enclosure, as I recall them requiring about 15L to operate properly-- that's 3.5 gal, 15000 cc's, or (15000cc/2.54^3in^3/1728in^3 per ft^3 ) -- About .535 ft^3 ---
The factory enclosure is about half that volume-- Unless you doubled it's volume, which I doubt, it wouldn't have been the ideal enclosure for the 5.25--
Down to a certain freq, the 6.5 will be louder even freeair, but will always lack in LOW extension, 65hz~75hz just won't work that well--
Focal's are extremely good quality, but are still limited by the same limitations of every other cone driven by a voice coil damped by a surround and spider-- Their displacement needs to be aligned with a certain volume, and when this is not done, there are a few things you can do to make the suspension stiffer for cone control, but compromises begin to happen--
Again, VERY rarely will you ever see pro-sound or home theater EVER use IB alignments for subs, mids, or anything-- even tweeters and mids have chambers for tuning-- A midrange soft dome for instance will lose a great deal of it's low extension without a tuning chamber behind it to tune it's rolloff--
BUT-- FOCAL IS awesome, and I am in no way knocking ANY brand out there whatsoever, all automotive audio manufacturers have a very difficult task on their plate to design a perfect speaker in very very very imperfect conditions, and it's really just impossible to do--
I only commented on the actual benefits of a true 3rd order alignment vs. an Infinite Baffle alignment and it's inherent benefits--
This is why Lexus/Toyota paid engineers to design the audio system, and it's not strange that they chose ported enclosures with a 5" mid-- it will play lower and higher and more efficiently with a less expensive driver than many more expensive drivers in an IB setup--
captainsc
SC400 / 300 Classifieds
05-13-08 06:40 PM
