gain settings
gain settings
hey guys. i have a headunit that is advertised as having a "high voltage, 5V" output. i recently purchased an alpine pdx amp and am having trouble setting the gains. the dial is labeled as follows: all the way to left is "min", which the manual says is 4 volts. At the top center of the dial, there is a sign that says "NOM". And all the way to the right is max. What should I set the gains at given i have a 5 volt output? I wanna get the most sound out of my amp as possible.
thanks.
thanks.
hey thanks for the reply. what you said is what i've generally been hearing. i was wondering what the "5 volt preout" was referring to. i thought it had something to do with teh gain.
basketthis
09-29-08 04:25 PM
jucee187
05-13-04 08:00 PM
