My Fist Time - 1st Stereo Install This Past Weekend - LONG - Several Pics
Originally posted by amlin423
Dex,
Just wondering...with your sub mounted like that...does your rear
deck panel rattle? Did they do any dynamatting?
Dex,
Actually, I pretty much believe he could build damn near anythng I ask for - he appears to be rther inovative and creative, and certainly has the shop to do so.
Yes, they did D/M the entire topside of the rear deck; you mean you missed the pic? (#10 abpove)
can you hear any evidence of the line level converter? I ask because I am jumping back and forth between a LLC and an amp that has high level inputs. You LLC was made by Monster cable? I tried searching their site with your part number but couldn't find anything.
Moderator - Electronics Forum
Gen1gs,
I still like these guys for LLC's. Good stuff.
http://www.linkmeup.com/pl2.html
Dexter,
Looks like you've got a good shop on your hands. Believe it or not, YOU could have done something like that...easy. It all looks overwhelming but if you take it in bite sized pieces and handle a little bit at a time, you'll find it's well within your reach. Still, there are little tips and tricks that I'll include in "the book". How is your power wire routed?
Percy
Dexter,
Percy
Amlin423,
I know what you mean. I only have the option of working on the car myself as I don't trust very many people with the caliber of equipment that I have. But, there's nothing like doing it yourself to get some practical experience! As Mean Gene and I can attest, there have been many times in the trunk working on the wiring with Pizza and Pepsi nearby. I always try to back the car into the garage so the kids won't see the equipment in the trunk. As soon as anyone sees the Velodyne magnet hanging down, they freak!
Percy
Percy
Dex,
DaveGS4
I know...it's great to have 3 people to work on a car...I did everything myself...most of the time with the wrong tools cuz I spend everything on my equipment...then i have a girlfriend who yells at me for spending so much time with my new girlfriend (my car stereo) so basically it's really only 1/2 of me doing my car and 1/2 of me fending off my girlfriend who's constantly beating me with a stick.
Dex,
DaveGS4
absolutely right percy...trial and error...gotta learn it the hard way sometimes...i broke two things in my GS...one is when I tried to take out the rear pillar panels...broke one of the things inside...but there's no way you can tell from the outside...and another thing is those things that hold the doors panel and the actual door together...i bent that badly because I tried to push the panel back when it wan't aligned right on the hole.....but there's enough screws and those things in there to hold the door perfectly anyways....with the right tools...those two mistakes could've easily been avoided
oh...and you'll always get some cuts and bruises...and sometimes some wire copper stuck in your fingers...(those HURT!!)
Originally posted by gen1gs
can you hear any evidence of the line level converter? You LLC was made by Monster cable?
The cables used for the LLC were MC; the units themselves, not sure. Let me see if I can get my invoice for you and see if they list the manf. I went ahead and used a quality of cable one more than I needed that included the available plugs that will let me control the sub from my upgraded HU once it is installed.
If you have your pick, I'd go with whatever Percy suggests ; I put full trust in the guys at the shop for mine; I'm pleased.
HTH
Percy
Percy
Box Sizes
Dex & Dave - Since ya'll both have the same sub & amp combo ( & I'm hoping wired the same way? ), if U get a chance to dB the cars, be sure & post those numbers ( & the box volumes ) so that the rest of the Members get a better idea of how important the enclosure size can be on SQ & SPL. IME, the smaller box will be tighter & yield itself to better SQ while the larger box will hit harder - but I've been fooled before!! I know that there R other variables like battery condition & especially the meter used for measuring the pressure but ballpark figures will be fine for argument sake!!:eek: Seems to be a nice basic SQ install that U deserve credit for researching beforehand. Congrats & enjoy!!
Re: Box Sizes
FWIW, the lead tech installer told me that the enclosure size is super important, and mentioned some direct relationships like what you stated above.
My battery does need to be upgraded though - I got that speech. Not because I run a super power system, just that mine is getting run-down, and battery performance effects sound quality, even though my amp regulates the flow...the flow is getting slow
I was hoping I'd hear your opinion MG!
What is SQ?
Alphabet Thing!
Dex - SQ stands for "Sound Quality". Percy's working on his "ultimate SQ" system but with the choices of Velodyne, DynAudio & McIntosh, he certainly has the components for it! He's also been known to "improve" things, if ya know what I mean!! I ain't THAT talented!! BTW - SPL stands for "Sound Pressure Level" but I'm sure U knew that. Hopefully Master P will include some definitions in his/our book ( if I ever get off my butt & get my pics & info to him!! ). For your battery needs I'd look into the Optima Yellow Top. It has 950 cranking amps ( 750 cold cranking amps ) which is the same as their Red Top but the Yellow Top is designed for deep cycling & will allow numerous "zero discharge" cycles before crapping out. I HAVE killed a Red Top years ago with my S-10 ( twelve 10" subs & 3 RF Punch 200's ) but that was before the advent of the Yellow Top. Don't even think about a DieHard or something along that line - they aren't designed for heavy current draws & Sears will give ya a hard time about replacing it under warranty ( "the battery's NOT designed for that kind of usage" was the story I got ). There R two models of the YT but the only difference is the location of the terminals. www.optimabatteries.com
Gene,
The only thing that Sears makes well - their handtools. I've worn down a few precision screwdrivers and they've always replaced them with no questions asked. Now anything with moving parts is difficult to warranty since there is wear involved.
As for their DieHard batteries, well, they die fairly easily. Remember the "switchable" ones a few years back? Supposedly had a reserve incase you ran down the battery? Well, it turns out that the reserve drained at the same rate as the main battery. I'd like to find the engineer who thought of that one and whap him!
Percy
Percy
Percy
MG, you said the location of the terminals are different..you mean...positive on the left side and negative on the other right?
Couldn't I just turn the battery around, or would that not fit...I have never taken out my battery so I don't know what that looks like....
Percy, 4 gauge wires in your fingernails..that's gotta be hell..
BTW...I used your EQ settings...everything was nice except I thought the bass was a bit too much so i tuned 100Hz down to +3 dB instead of +5 .....Celine Dion's "screaming" still hurts a bit though...i kinda wince when she hits some of her high notes as well as the Glitter girl Mariah Carey (esp hers) ....Man...parametric EQ's are NOT easy to learn....I'm have so much trouble with it..
