Speakers quiet even when turned all the way up
Okay so here is the story and need some help...
Take my 92sc300 into auto car wash at a gas station (only sprays around and under no brushes). So it is doing its thing and car is getting pretty...radio is on. Next thing I know it sounds like a pop. Radio goes silent, sub keeps bumpin. Later on sounds like rice crispies snap craklin and popping. Now...radio works and sounds comes out but at full blast it is BARELY loud enough to hear with the windows down....
Any ideas on what the heck happened, what I can do to check, what I can do to fix? All help greatly appreciated
THANKS GUYS!
THANKS GUYS!
THANKS GUYS!
THANKS GUYS!
I have same problems with my 01' LS430 ML system. Now there is no sound at all when the radio is on or the CD is playing. The popping, rice crispies, snap, craklin sounds sometime can get really loud that i thought the speakers are about to explode. You might wants to check your Amp if any water get in there. I haven't figure my problem yet.
sounds about right-- if the sub's still playing -- the head unit is still sending signal to the amps-- so if the amp is making noise but just not enough you know it has signal too--
This leaves a pretty easy puzzle to put together-- high pressure water sprayed upward toward a vent just below an amp-- amp goes pop snap crackle-- no more sound-- yadda yadda yadda--
time to hit aliga up -- dude's got every part of an SC available in great condition nearly all the time-- I've bought lotsa stuff from him with no prob whatsoever-- super good guy to get stuff from--
I had a somewhat similar problem this last winter after allot of rain. The head unit had power and you could hear sound from the speakers ever so slightly with the volume at max. I decied to gut the system ,and in the process I was taking out the back seat and discovered all water in the car underneath the driverside rear seat. It also just so happened to have a connector that I was guessing was for the factory system. I guessing that water was causing a short. Im not sure, but it sounds alot like the leak I had. Good Luck!
So where is the amp in the car? Is it under the seats or in the trunk area under the cd changer? Thanks for the insight hopefully I can get this resolved sometime soon so I dont have to barely hear the radio on my way to work since my a/c isn't working either = windows all down!
amp is under the cd changer -- (in the trunk) -- you have to pull up a piece of foam to reveal 2 hidden nuts also--
That is if the system is a lexus premium -- (pioneer)
flipboi
02-23-08 11:43 AM
