Pop in speakers
Pop in speakers
I keep hearing this "pop" in the rear speakers whenever I turn them on, especially when I first turn on the car. An amp is connected to them. What could be the problem?
Exactly When?
If the "pop" happens when U turn the key off, try shutting down the stereo before turning the car off. If it happens when U turn on/off the system itself, check your ground wire on that amp. Do U have noise anywhere else in the system? Typically, an improperly grounded system will demostrate both ignition noise as well as a power related "pop". Also consider turning the gain down on the amp. Good luck troubleshooting!
sivikvtec
08-20-13 09:25 AM
Pyroneer
14
07-18-03 10:32 AM
