2gs3 Sub Installation
Is there anywhere to connect the signal wires from an amp to the back of the stock gps headunit?
Can i use the speaker wires that go to the rear stock sub and plug them into an aftermarket amp to power some subs?
I dont know about queston one but i can answer question 2...You will need a LLC (low lne converter) tap that into the wires running into your stock sub..the LLC then changes the signal into RCA's which then go to the amp and the rest is history.
https://www.clublexus.com/forums/sho...d.php?t=109329
Is this what I need:
http://cgi.ebay.com/LOC-Line-Output-...QQcmdZViewItem
Its an ebay link for an High to low level converter.
Heres a couple more:
http://cgi.ebay.com/CAR-STEREO-HIGH-...QQcmdZViewItem
http://cgi.ebay.com/ebaymotors/Speak...spagenameZWDVW
They all look kinda cheap to me...what do you guys think?
hmm...ill give it a try. Yep..just bought it!
As for the subs i finished making my mdf enclosure, that should fit snug under whre the stock sub is.
2 12" Polk DB's and a Kenwood 6202 Amp should be pretty decent right? Im kind of on a budget. i would go with 10" subs, but i relaly like look the of the extra size of the 12's, and they are only $8 more at my local store!
DK Audio
14
06-10-12 07:49 PM
ls_lextasy
09-02-09 05:34 PM
1995LS400
09-21-07 12:15 AM
cal9126
07-05-05 01:00 PM
