Another help plee from MKii240 installation.
Old 01-02-02 | 02:34 PM
gsnav's Avatar
gsnav
Default Another help plee from MKii240 installation.
Where do i put the crossover? The crossover is huge so someone please tell me where i put it, cause i'm installing it for the fronts, i need help. I can't seem to find any space that'd work so the whole door can be put back properly. Thanks.
Old 01-02-02 | 02:36 PM
LexusRules's Avatar
LexusRules
it should go inside the door... if its in a big case you could consider taking it apart.. or mounting it under the front seat
Old 01-02-02 | 04:57 PM
Percy's Avatar
Percy
Moderator - Electronics Forum
any space on the reverse side of the baffle board?
Percy
Old 01-02-02 | 04:59 PM
amlin423's Avatar
amlin423
You can definitely fit your x-overs in your doors.....just stick it further inside the door and make sure window doesn't hit it..I just laid them in before I stuck them on and I had absolutely no problems with space...I don't have them in anymore since I'm using active x-overs now.....secure it with double sided tape or something.
if you can't close your door panels...you must not have shaved off enough "pig's feet" I shave it off until the leg was about 1/4 inch thick and I still have to give it a slight push while screwing it in. As long as your the door panel is not on your cone you're fine.
Old 01-02-02 | 05:57 PM
gsnav's Avatar
gsnav
thanks amlin, but which legs do i shave off? both, it seems that my spacer might be too thick. I can close the door no problem with just the pig but with the spacer i cant.
M88JCP
05-23-13 08:51 PM
ATLien
09-15-08 08:35 PM
Bluesman
10-14-05 02:00 PM
92Es300 5sPd
02-16-03 07:24 PM
stoked
SC- 1st Gen (1992-2000)
08-31-02 06:27 AM
