70-8112 harness discrepancy?
I found the 70-8112 integration harness pin connections here:
http://www.metraonline.com/downloads...NST70-8112.pdf
Pins 8,9, and 10 don't seem to match what's shown here:
http://www.intellexual.net/faq/lexusstereo.swf
Can someone confirm which is correct for the SC300 Lexus Premium Sound System?
P.S. I later found this:
http://carstereohelp.net/wireharness_Lexus2.htm
It seems to confirm that 8 is Power ntenna, 9 is Ill-, and 10 is Tel Mute
All this takes is a little repinning of the wires. I had to do this with my 2nd Gen GS. It is a little mixed up but compare the wiring on the Metra Harness and http://www.the12volt.com/installbay/...ard/Lexus.html.
Factory amp will be circumvented and you will have to extend the wires to the factory amp to bypass. The power connections are a little trickier, for those I suggest looking from behind the factory stereo.
92EGSi
08-10-04 10:02 AM
