Can you retrofit a 8 ohm driver to act as 16 ohm?
My Mark Levinson Sub woofer is history... I Correct me if I'm wrong but i'v read that the ML Subwoofer and Amp run at 16 ohm on my SC430 2003. Is there any way to wire a 8 ohm rezistor to an 8 ohm subwoofer (lot's of cheaper choices than a single 16 ohm woofer) for a total of 16 ohm without the risk of damaging the amp?
Please let me know!
Please let me know!
You'll need a subwoofer with dual 8 ohm voice coils and run it in series...GL finding that.
Other then that, there's no way of converting a 8 ohm woofer to a 16 ohm woofer...at least not that I know of.
actualy there are alot of subwoofers that are dual 8 ohm, most would be home audio subwoofers. Partsexpress is a good site to check, www.madisound.com has alot more choices. There are ways to wire resistors to make a 8 ohm coil have a 16ohm resistance. I dont know exacally which resistors u would need but it can be done.
-Robert
Wouldn't this do the job?
http://www.radioshack.com/sm-8-ohm-n...i-2062288.html
Thanks for looking friends!!!
That's only 20w. It will burn out (flames) if you turn up the volume for any length of time. This is more like what you need - link. I'd go with the 200w model so it won't heat up as much.
-Robert
-Robert
jpv7774
12-26-15 11:06 AM
RodF
06-09-06 11:08 AM
