Need help with Line Output Converter
I have an 01 LS430 w/ Navi . I am trying to connect my 2 subs and 4 speakers to an aftermarket 5 channel amp while still using the stock head unit. I have already found the wiring diagram for my car. My question is
1. Do I use a 4 channel line output converter for the speakers inside and then get another 2 channel line output converter for the subs or will (1) 4 channel line output converter be enough.
2. Where would I install the line output converter? Does it go close to the amp or does it need to be behind the head unit?
3. Should I rewire the speakers to the amp, or just connect the old wires that were going to the stock amp?
Moderator - Electronics Forum
1. Get one for the subs. Audiolink makes some good ones. Not cheap though.
2&3. Line out converter taps the signal from the stock amp. Then feed the signal output to the aftermarket amp. Aftermarket amp to the speakers. Install in a place which would be conveinent for you!
