Please share your Eclipse AVN Splash (startup) screen
well i figured i would help everyone out with this question, just got off the phone with Eclipse and here is what they faxed me over.
Step 1: When storing the image data in a CD-R/RW disc, make a text file named "CSM.txt"(any content/text is OK) and store it together with the image data.
To create this necessary file, open Microsoft notepad in Accessories. The text data within the file does not matter. Simply save the file as "CSM.txt" and include the file on the same disc with the image you wish to use for the opening screen.
Tip: if you need to modify the image to fit the AVN screen you can use, MS Paint or any other image adjustment software.
the format of the disc and image that can be used on the opening screen are shown below. if your disc and/or data does not meet the conditions below, the file names may not be listen or displayed.
File Size < 100KB
File Name ISO9960
Writing Method Single-session only
Image Size 416(w) x 240(h)dots <max>
Step 2: Dowload Image to CD-R/RW
1. Insert a CD-R/RW disct that includes your favorite image
*it will take approx 30 seconds to read the image data. While the image data is being read, do not operate or alter the ignition key.
2. Touch opening image change
3. Touch the image you want to display on the opening screen
4. Touch OK "Be sure to eject the CD-R/RW disc that includes the image data"
and there ya have it!
Happy Turkey Day!!
File Size < 100KB
File Name ISO9960
Happy Turkey Day!!
there's nothing in the manual for the AVN5510/6610. I also called Eclipse tech a few times and they told me that it should work regardless. guess I'll have to keep trying.
BYPASS LOCKOUT on Eclipse
Is there a bypass procedure for the Eclipse nav units so you can make route changes while moving? I know there is lots of info on Pioneer lockout bypass.
