extra battery? 15 farad capacitor? both?
im in the process of doing my system and was thinking of using a phoenix gold powercore xl (15 farad). it will be drawing its power from an optima yellow top and will be powering a 350w amp, 450w amp, 2 viair 380c compressors, and a couple sound processors. i have a 300w amp in the car now, and when the compressors are on, the voltage drops and varies between 11-11.4v when im idle and varies between 12.3 to 12.6v when im driving. now my question is, would it be better to use a second yellow top battery or use the 15f capacitor to solve my voltage problems?
your problem is that you do not have enough power to start with. Adding a very huge capacitor would put additional strain on the electrical system. Same with adding a second battery.
And I highly recommend looking at some other battery as a second battery. Optima batteries aren't made like they use to. The yellow has poor deep cycling capability. Drain the battery below 10.5v a few times and I can guarantee you it's going to die out eventually. It's been tested before so I'm not making this up
Do it right and get a bigger alternator. It's expensive, but it's what you should be doing in the first place.
i had an o1 gs430 i had 2 tvs in the headrest mini ps2 2 12" rockford fosgates and 1 amp my 01 gs430 was giving me alot of problems also idling on 11.4 11.5 which isnt good i juiced up the alternator and after a while bearings in the aftermarket alternator got jammed while my car was idling i now have a gs350 07 and iam thinking about putting a system but if i need to change an alternator iam not doing anything
its not a joke putting an aftermarket alternator and having your bearings in the alternator jam
goodluck
goodluck
goodluck
goodluck
I have a 01 430 too...and I was thinking abt upgrading my power..since i push a lot of bass...
As an alternative to the Optima check out the Sears Die Hard Plantinum batteries, which are backed by a 4 year full replacement warranty and are deep cycle capable, and have an excellent reserve capacity. Picked mine up for $180 and its been great.., and my setup runs 1200W RMS (rated at 12v), and at 14.1V it pulls more..
i have a 98 gs300, 2 digital designs 12" dual voice coil 2ohm woofers, running off a mmats 2200.1 amp, powered by 2 optima yellow tops, 180 amp irragi alternator, when the bass hits my voltage drops down to @ running idle 12 vlts and my amp is wired @ .5ohm and trust me it is LOUD. my advice would be the sears batteries, and give dominick a call from irragi alt his # is 6152877991 tell him kenny sent ya from philly he does alts for competiton cars i had 1 in another car i had when i use to compete. he could set u up with an external regulator, and external rectifier setup. its more effiecent that way. just give him a call. he will hook u up, tell him u want the smaller pulley on the alt.
bass911
45
09-20-13 10:10 PM
jbreezy27
11-08-09 08:51 PM
