OEM Integration for Sirius And iPod possible?
I'm a proud owner of a new 07 black-on-black GS 450h with Nav & Mark Levinson. I've been researching various options for satellite and iPod integration, but there doesn't seem to be a solution that offers both fully accessible via the Nav unit.
Is it possible to use a combination of the various Sirius and iPod integrations to allow for BOTH Sirius and iPod control via the Lexus interface? Any recommendations?
For example, could I use the Scosche AXIPTA or and Vais Tech SoundLinQ2 (SL2Vi) for iPod and a Vias Tech SoundLinQ (SLS) or lexus-parts.com Sirius Fit-Kit for Sirius?
Otherwise I think I will just need to make a trade on what I want to have fully integrated into the Nav vs. partially integrated via an Aux in...
I already have a Sirius Sportster that needs a new antenna... I could pick one of the iPod interfaces with AUX in and just run the Sirius into that and then control it via the Sportster interface that I could get mounted into my center console.
Does anyone have any recommendations for good installers that deal in Viastech and Scosche in the Northern Virginia/DC Metro area? Best buy said that if I bought all the stuff I wanted they'd install it (about $75/hr, probably 1-1.5 hrs).
I have a 2005 ES330 with Nav, 6 CD changer, and Mark Levinson, and I'm essentially looking for the same thing - sirius & ipod integration. The VAIS SoundLinQ SLS looks to be the best option, but I'm not 100% sure it will work. Has anyone done this install on a similar system & are they satisfied????
As far as I can tell from their website (http://www.vaistech.com), you can only use one vaistech adapter with the head unit. Which vais adapter do you have, AM1?
Success: Vaistech SoundlinQ SLS in my 2005 ESS330 with Nav
Hey all,
I took a chance and installed the SLS adapter with the Sirius SIR-PAN1 tuner. Now I can listen to and control my sirius radio through my Nav system, and I also have an aux input for my ipod. I just posted my install experience here.
Installer?
Did you find an installer ? Any recommendations?
just some extra info
I'd look into Isimple items. for your setup you want. Full ipod/iphone interface and full Satellite Radio Control with NAV displays/charging/and use of all OEM controls.
ISimple ISTY571- $189.95
ISimple ISSR11 - $59.95
Sirius SCC1 - around $69.99
BBY - Install around $130 flat rate. Some bays may charge hourly but since BBY sells the SCC1 for $60 and ISimple is a brand BBY carries you have a case to avoid the hourly if the installer is slow and decides to charge you a ton.
goodluck
goodluck
