my carpc install
Old 01-12-08, 01:21 AM
  #91
pnyboy27
pnyboy27's Avatar
so far..im getting mad votes for the leave it black. i guess that would look even better once i do the black/tan interior. where its the dark brown color, i plan on getting those in black. then the steering wheel the same black with also a wood trim.
Old 01-16-08, 01:07 AM
  #92
pnyboy27
pnyboy27's Avatar
update: i just got in my power supply and my power supply adapter for the carpc. i just took it apart again and will do some minor touch ups to the center console and install everything again, and this time with the clean 'final' look. then after this...time to save up again for another 4 channel amp. then redo my trunk with the subs and amp setup. woo! this is going to be some fun stuff!
Old 01-21-08, 12:07 AM
  #93
pnyboy27
pnyboy27's Avatar
i have an aopen pc with a carnetix p1900 v2.2 power supply. im pretty sure i have all the connections correct, but for some reason, it doesnt turn on the pc. heres what i have connected:
input:
2 reds to battery via 15 amp fuse; 2 blacks to ground; yellow to ignition wire(ignition wire from stock harness to stock headunit), blue taped up and closed
output:
red/black to comp; brown/black to screen; red/green/white taped up and closed; green/black adapter to jp3 slot on power supply p1900 to computer acpi; blue wire to amp remote
when i connected it, and turn on the car, the p1900 led lights up twice, then once, then 7 times, then no light. according to the troubleshoot on the installation manual..it says to check the battery..because if its less than 10.6volts then it wont start or light up..but my battery tested at 12.77 volts with a full charge, 45% state of health...could it be my ignition switch? is the switch i have no small? when i checked with a multimeter, it showed around 12 volts coming out of it too. im so lost and confused! i just need this to turn on then my project is basically done! HELP PLEASE!!
oh, and just in case, heres my comp specs:
AOpen MiniPC i945GMx-F
Intel Celeron M 440 (Yonah) FSB533 1.86GHz
Old 01-21-08, 08:33 AM
  #94
shern
shern's Avatar
Have you tried jumping the ignition wire directly to hot?
Have you tried disconnecting the ACPI?
Old 01-21-08, 12:27 PM
  #95
pnyboy27
pnyboy27's Avatar
no i havent tried jumping the ignition wire yet..but i will try that now to see what happens. i hope that solves it..but then if thats the thing..where would a good ignition wire be? and as for disconnecting the acpi..i havent tried that either..ill try that too to see what happens. as for the diagram..i actually used this one because this is the exact kit i got and all:
Old 01-21-08, 01:43 PM
  #96
pnyboy27
pnyboy27's Avatar
okay..i just tried jumping the ignition wire to the hot, and removed the acpi..still didnt work. i just tested the input of the psu, and it read a nice 12.6 volts..then i tested the output of the psu..and it read a 0.12 volts..that isnt right is it? so does that mean i have a bad psu?
Old 01-22-08, 05:20 PM
  #97
pnyboy27
pnyboy27's Avatar
heres a picture of my ground...which is found under the dash behind the glove box compartment
Old 01-22-08, 07:26 PM
  #98
shern
shern's Avatar
Take the system and fire it up with an ATX power supply to ensure that board/cpu is still okay. If it fires up, then there may be an issue with the PSU. You could also try hooking up the carnetix supply to a motherboard in your house.
Old 01-22-08, 09:54 PM
  #99
pnyboy27
pnyboy27's Avatar
well im pretty sure my comp is still okay because i can still power it up at home via the wall power supply
Old 01-28-08, 08:01 PM
  #100
pnyboy27
pnyboy27's Avatar
okay...well i got my new power supply in today and when i checked it out, i found out that the only reason why my other one wasnt working was because i was missing a jumper unit. so i picked one up and now, i have two working psu's. i finally finished installing the whole thing and will take some pix as soon as i can..which may likely be tomorrow. but everything works like a charm now! i love it!!
Old 01-28-08, 08:11 PM
  #101
shern
shern's Avatar
How much for one of the power supplies?
Old 01-28-08, 10:10 PM
  #102
BLK13X
Mortgage Slave
BLK13X's Avatar
WOW! Very nice work dude, I say leave the console black, it looks more OEM (but I like OEM looking things )
Old 01-28-08, 10:56 PM
  #103
pnyboy27
pnyboy27's Avatar
did you want to buy my other one? ill pm you the price because i know this isnt the correct thread for selling, and i dont want to get in trouble for it
Old 01-29-08, 09:04 AM
  #104
chanh55
chanh55's Avatar
It's always some little thing you forgot to do....
One time my board wasn't powering on and an rip the whole console apart only to find that I forgot to connect the ignition wires to the switch I made...
Old 01-29-08, 01:35 PM
  #105
pnyboy27
pnyboy27's Avatar
hahaha..i hate that! i did that a couple times with my screen
Quick Reply: my carpc install
