Stock Sc Sub
Hey another question here
If anyone can help me out
I have the factory sub in my Sc but it isnt connected the wire is cut and pulled out
I want to know what wires go from where to where to make that sub functional
From amp to sub ? or sub to somewhere else
and if it does go from the amp to the sub anyone have a wiring diagram or schematic ?
Thanks
Thanks
If I remember correctly the sub wire is yellow and black. You can do a search here for the wiring diagram or find it on Intellexual.net (I think). The amp is under the changer in the trunk so you may be able to pull the trunk skins out and trace it from the amp to the sub. Once everything is out you may be able to locate the cut wire.
AP2
12-10-14 10:40 AM
Frankdorn
05-28-10 10:26 AM
