hid lights for lexus
I have a question about hid lights. I know the main head light is a 9006 bulb and I think the fog lights are h3's. The year model of the car is a 97. My other question is how hard is it to install the fog lights hid kit. I hope this is enough information. Thank you for your time By the way if you have pics of your car with both the head lights and fog lights with hid kits please post of picture, so I can get an idea on how it will look. Thanks
Its a *****.
If you do a search, there is a detailed write-up for this procedure which I used and it worked well. Doing HID's in your foglight housings will make them turn into driving lights. They will be useless as actual foglights FYI unless you have a very low K HID set (like 4300 K or so).
The main thing about replacing the foglight bulbs (or doing HID's) is dropping the black plastic undercarriage protector. There are a bunch of 10 or 12 MM bolts holding it up. You'll also need to peel back the inner fenders as well. The drivers side is quite a bit tougher than the passenger side because of the piping.
garyr
04-17-08 02:25 PM
YoshiR6
08-29-07 08:25 PM
