hey can you reload the pic of the mounting...it is saying moved or deleted.
Also can you show us some snap shots of the thumb drive or is this not done yet. I have been looking to begin building mine as I want this setup so I can run the AEM without any additonal units in the car (ie lugging a laptop around).
is the radio intergrated??? where is the tuner?
I have an HD radio receiver which is plugged into the PC and controlled with Centrafuse.
Originally Posted by gs4004gs
I just realized you don't mention what you're using for GPS? I don't see anything mentioned about that. Could you inform please?
I'm using iGuidance with a plugin to use it in Centrafuse.
I will reload the install pictures later today
The thumbdrive is not finished yet.
As for the AEM, I'm using the power FC with the Datalogger and being able to monitor and make adjustments w/o a laptop is awesome.
do you have the centrafuse with nav, or regular centrafuse and using iguidance? and have you had any experience with centrafuse's nav? im planning on using centrafuse also, but would like to know how their nav interface is.
Sorry I meant hardware... what hardware are you using to get the signal. Thanks in advance!
A lot of dudes just use the GlobalSat USB GPS receivers that look like a puck and they pull the signal in quite nicely since it has the SirfSTAR chip in there. Things are cheap as well, like 30 bucks.
Beautiful dash. Got anymore pics of your dash/interior?
Thank you !
I'm actually using the GPS sensor that came with a copy of Microsoft Streets and trips I had. its small and works pretty well
I got sponsor by Centrafuse and they provide the Standard Edition w/o Nav and I have never used it so I cant really say.I know it looks nice from what you can see on the Standard version.
Anyone planning on doing a CarPC should jump on the sale Centrafuse is having. 50% off the software !!! thats $125 for Nav edition and $62 for Standard !!!
You have outside shots of the car buried anywhere?
Thank you very much. The car is in the Current April issue of Modified.
Originally Posted by sam430
Why didn't you put the gut in the trunk instead of oem ddin housing?
No wiring to run from the back of the car.
If not I would have had to run:
•USB for touch screen
•RGB for screen
•USB extensions for hub
•SERIAL for Power FC
•WIRING for reset button and Power LEDs
•WIRING for 12+ and Ignition
•USB for Slot DVD player
No thanks!
Originally Posted by RX469
Who fabbed up the guages in that panel? Looks great. Got any pics with the guages on. Thanks.
A local guy here made the pods, He is working on my rear led lid now as for the pictures Ill look to see if I do.
Ok I am officially jealous! Your car is in my top 5 (as if that means anything to you!) of Lexi... Lexuses... Lexus' (plural Lexus?) that I would dis my own mom to own.
Gorgeous car and you've done it justice with your efforts.
aw shucks, thanks you. Alot of time and hard work went into this.
Originally Posted by EN_VY
Wow bro, thats SC is HOT!! I love the silver interior, was it custom or did you do it, if so how? Mad props on the car bro
Thank you the interior was originally wood, and had all the trim painted at the same time the gauge pods were made.
Originally Posted by rgarjr
Was it Nexson from mp3car?
No Actually my Friend Otto in Tampa. I can give his contact info if you'd like.He is working on a fiber glassed rear deck for two 6.5"s and 1 10" sub.
