adding bass to stock sterio
Whats up everybody. I have a 1993 es300 i like the stock stereo i have the 1 with the 6 cd changer it says premium stereo i would like to have more bass can i add a bazooka tube or a sub box with an amp onto the stock system or do i have to get a new head unit. Thanks.
yes you can add a box or bazooka tube to your stock stereo. the easiest way is to tap off of the sub speaker. that way you can still use the stock sub. to do this. you just splice off the wires and hook it up to an amp with a built in high/low level converter. (kenwood amps have them) otherwise if you use an amp that doesnt have a high low level cnverter you can buy it seperaty for like 15-30 bucks. thats basically it. if you have any more questions. just ask me. also if you are looking to buy any equipment let me know. i get alot of new equipment for unbelievable prices. just ask and i can prove it, no obligation. lol ok hope that helps.
Thanks for the info they sure get alot of money for those amplified bass tubes i have a kenwood amp and passive box but i just wanted to put in a sub like a bazooka tube.
I guess your right I have to run all the wires anyway the only thing is my amp is about 7 years old it was rebuilt it a kenwood 360 watt but i dont know if it has those plugs you were talking about if i do hook it up do you know what i'll need.
uhm its hard to describe, but there would be inputs for bare wire. they would almost be next to the rca speaker level inputs check that first. i would say best bet is to spend $200 or so and get a new powerfull amp. other wise i wasnt really sure what you were asking, hope that helps.
![Lightbulb](https://www.clublexus.com/forums/images/icons/icon3.gif)
Todd - Go with a sealed box & external amp over a tube ( Bazooka or otherwise ). While I think the tubes have their place, the bass tends to be muddy & the amps R weak. Also, the crossover isn't very precise. I've had both amplified & unamplified Bazooka tubes ( 8" & 10" ) & if forced to choose, take the unamplified version & get an aftermarket amp for it. But for the better sound, try a sealed box/amplifier combo.
Thanks for the info guys i think i will put in the box i have should fit perfect and i will check that amp for the right connections i might use what i have than spend more money the amp is at my parents i'll update you guys when i go and get it. Thanks again.
Daihuy
17
04-13-07 05:36 AM
