Desperate!! SC400 wiring
Okay guys, I've tried posting this on SC400 but not having any luck. Totally installed my system, but can't find the power antenna wire at the harness behind the radio. Out of all these installs, someone has to know. 95 SC400, Premium system.
By the way, if anyones interested, geting rid of 12 disc changer and the deck. Amp does not work anymore. Any offers??
Thanks,
Shane
Will be posting pics soon.
Thanks,
Shane
SSmith, I'm looking at the diagram but not sure if I'm reading it right.
back of redio receiver assembly:
____ ________ _______ _______
|___| |_______||______ | |_______|
conn
ector
"B" "A" "C" "D"
and there are 4 connections to "motor antenna assembly".
2 from connector "A", and 2 from connector "D".
Connector "A" : 4 3 2 1
10 9 8 7 6 5
Connector "D" : 4 3 2 1
10 9 8 7 6 5
from A1, "AMP" is connectiong "AMP" on Motor Antenna Relay.
from A8, "ANT" is connectiong "ANT" on Motor Antenna Relay.
from D4, "ANT A" is connectiong "ANT A" on Motor Antenna Relay.
from D10, "ANT B" is connectiong "ANT B" on Motor Antenna Relay
correct me, if I'm wrong.
conn
ector
"B" "A" "C" "D"
10 9 8 7 6 5
10 9 8 7 6 5
I have the diagrams & layouts for my 93 sc400. If you would like, I can FAX those pages to you tomm. It should be the same as a 95.
I would also be interested in your 12 disk changer.
E-mail me with your fax line number & I can send tomm.
B-
PS, I believe the 12v for the antenna is the same that supplies V+ for the amp in the trunk, so that may be of some help.
B-
cna anybody tell me where i can get a stereo wiring harness for my 1993 sc400, if not how to wire an aftermarket stereo. There's like 3 or 4 harnesss's in the dash and i don't know what wires to tap into as far as where speaker wires and acc+ and ground are.
Just too many wires, please somebody help! thanks!
cool, thanks for the info, i looked at it, and was wondering how could i use the existing sub and sub amp? which wires do i tap into to make it turn?, thanks again!
sparkyguy
04-24-15 03:12 PM
