[HELP] alternator whine on SC300 with 70-8112 harness!!!
Dear CL members,
Dear fellow members, I had a hard time to get rid of the alternator whine noise, I am using 70-8112 harness, but somehow I can not get rid of the noise, is it because my ground lead is not strong enough which I should attach it to the frame, or I should attach it to the metal part of the car?
Don’t give me wrong I did my research on this issue for a long while, but I didn’t want to cut any wires or anything if I don’t need to. Many threads will recommend rewiring the speakers, or an aftermarket amp or something.
I wanted to run a Carputer, but I just wanna get rid of this whining noise first so I can start my project!!
Any feedback will be great appreciated!!!
Thanks you guys
Thanks you guys
Zombie Slayer
Since you are adding a seperate head unit to the factory system you should get no alternator whine. Did you make your own ground connections or add any aftermarket amps?
I removed the factory unit, and try to hook up a aftermarket unit to the factory amp. I was just try to connect the ground (Black wire) from the harness to the aftermarket unit's ground (Black one). I try two different head unit, they are all the same!!! and i tryed to ground the ground lead to the metal part where the shifting stick is (aorund center console) doesnt work!!
I had horrible alternator whine trying to use a new head unit in my es300, ended up just getting a new amp and upgrading the components. No more alternator whine plus a much better sound.
Zombie Slayer
thanks for the help man!!!
I really wanted to replace the HU since i did all my leds in Red, the a/c control and the clusters, so the HU doesn't match anymore, but due to the whining noise, which i tryed to get rid of it couple times already, still there and i am stuck with the factory HU right now.
did you hook up the aftermarket one directly to the factory HU or you replace the whole amp and the HU?
Dude! I feel you!!
I have the same problem when I replace my HU with Panasonic Strada mp3/Navi. I can't stand the whine so I went back with the stock HU. Is there a way to get rid of the whining sound without changing the amp?
