Replaced fuses still no power to radio
I had a short in the trunk which blew the Radio #2 fuse that feeds from the ACC/Ignition to the radio. I repaired the problem and replaced the fuse, but still have no power to the radio. I checked and I don't have power to the fuse box itself, so it is apparently not feeding from the ignition switch. Is there a possibility that the ignition switch may have been damaged, or is there something else that I should look for?
Thanks,
James
Thanks,
James
Yes,
The fuse in the engine bay was ok. It is for the "BATT" connection which is powered continuously.
The one that blew is in the kick panel. This is the one for the "ACC/Ign" connection which powers up when the key is turned on. The problem is that I no longer have power to the fuse box, so it apparently blew something between the fuse block and the ignition switch.
Thanks,
James
Thanks,
James
