Can I power an 8.4v device w/ this dc-dc converter?
Empress of the Known Universe
I frequently have a video camera in a track car and would like to avoid the hassle of changing & charging batteries for it. The transformer block on the camera (Canon Elura) states the electrical output at 8.4v DC and 1.5a. In order to hardwire this to take advantage of my car's 12v electrical supply, I understand that a dc-dc converter is the best/only way to go. The solution will have to be secured, high G environment
, and simple is key.
I found this which would seem to be perfect but know nothing about electricity and would like to know if a) it would work b) its 1.2a output instead of 1.5a might be a problem for the camera?
device details below & thanks for looking,
http://www.powerstream.com/daa-1209.htm
Model Number PST-DAA1209-2 $30.75
Input Voltage Range 10 VDC to 15 VDC Nominal 24 VDC
Peak Output Power 10.8 Watts
Peak Output Current 1.2 Amps
Continuous Current 1.2 Amps
Continuous Output Power 10 Watts
Output Voltage 9 volts DC
Output voltage options Optional voltages set in our lab:
8.4V, 8.5V, 9V, 9.5V, 9.6V, 10V
No-Load Overhead 20 mA
Load Regulation ± 3.4%
Line Regulation ± 0.3%
Efficiency >70% at full load
Output Ripple < 40 mV p-p
Topology Fully Isolated Buck Converter, case isolated
Protections:
* Input Polarity Protect
* Input Fuse
* Output Current Limited
Temperature 5 to 45°C (41 to 113°F)
Connection Flying wire leads
Protections:
* Input Fuse
Zombie Slayer
Krista:
According to the website the optional voltage outputs allow for the 8.4v that you require. Since the unit has a rating of 1.2a max output you do run the risk of blowing the fuse that should be included with the unit. It truly depends upon the the fuse that is included with the unit AND what the internals of the unit can handle as a draw. I would definately give the manufacturer a call and see what they think about a 1.5a draw vs. a 1.2a draw.
Zombie Slayer
Did a quick check of the website supplying the original product you mentioned. This item may fit the bill better:
Thank you for the suggestion. I looked around that site for a long time and those numbers, well, I didn't know which ones were important
I'll call the mfgr today and get their thoughts.
