HELP! - alarm related
I just got an alarm and had someone install it. the alarm is a Crimestopper Cs2014 remote start system.
my problem is the factory alarm. When I remote start the car, the factory alarm would go off. can anyone tell me what to do/how to disarm the factory alarm.
And, with my new alarm, it would only unlock/lock the car as long as the dome interior light is still on, Once it is off it will not unlock/lock the door, BUT the car will beep as if it locked/unlocked. The thing is, is that the car will still start from the remote but not unlock the doors.
I'm going to try and solve this problem tomorrow myself. the guy I had install the alarm had some good reviews, but those were from honda owners without factory alarms. the guy even admitted it challenged him because most of the wires were hidden.
any advice on what to do would be great.
hey you know i have the same problems sometimes too and i think we have the same alarm! mine is also a crimestopper!!
all you need to do is tap into the factory key-sense wire in the ignition cylinder. it is usually a very this gauge wire. when the key is insert into the cylinder that wire will read ground when you use a multi-meter. when the key is out it is just open circuit. you have to take a wire off the remote start that gives you ground while cranking. this should solve both problems for you.
i put in the remote start on my 93 sc300 and before connecting the key-sense wire the factory alarm would go off while remote starting. i have a DEI remote start and i used the blue wire on the unit.
what year is your GS? i can look up the colors for the key-sense wire at work. the only catch is im at school and will work next on thursday.
the factory door locks go to sleep mode when the car is locked, same with some toyota models there is a wake up wire that needs to be triggered when being unlocked with the aftermarket remote, dont remember what color ... though .. try a test when the factory alarm goes off insert the key in the ignition cylinder if the alarm goes off u can hook up the key sense wire .. if it doesnt then u gotta look for the factory disarm wire. let me know what year gs u have and ill send u an e-mail with the wire locations ..
On my GS which is a UK car but it may be the same. On the factory alarm there was a wire which dropped the neg when armed, this semmed to be an earth for the cdl as it would not unlock. All I did was to put this wire to earth and it solved the issue. I'm pretty sure it was a yellow wire at the alarm unit behind the glovebox.
like mkorsu said red/black it should be negative, to check turn the key in the door to unlock to check for polarity. being that you dont have factory remotes. try making the unlock wire to double pulse for unlock and set it up to send the first pulse to disarm the alarm first, the the second pulse will unlock the car.
I seemed to have fix it i think. I retraced the wires and there were 2 wires with the same color code for the "power unlock" both of which were black/yellow. I just switched the unlock from the alarm to the other black/yellow and it seems to work.
we'll see later on about the remote start/alarm going off problem.
oh and the thing about the installer/shop fix, I got the alarm installed up in Norwalk, and I'm down in san diego which is about a 2 hour drive.
EM Dot
10-13-07 07:22 PM
