I need help with keyless
I have keyless and car alarm and both been working great together. Everything was great until I replaced my valve cover seals and etc. When I was removing valve and pipe I had put some pressure on wires going to engine and now after I reconnected my battery my doors keep locking. SO sometimes when I drive the doors will lock once or keep locking . I can use my keyless to lock the doors but will not unlock. The alarm will lock and unlock doors but usually the doors will be relocked. Does anyone have wiring diagram for keyless. Are there any wires that are with engine harness that run along firewall and work with keyless. I noticed that there is ground point. Is my keyless ecu bad or ground point or broken wire?
Can someone help me solve this problem. I had found post with similar but there was no solution.
important things we need to know to help you solve your problem:
what kind of keyless/alarm system do you have?
what kind of car (make, model, year)?
we'll start there... then we can start figuring out your wiring...
BigWaveSC
05-29-06 04:02 AM
