Antenna Conversion
Old 08-18-08, 02:15 PM
  #31
TRD_Power
TRD_Power's Avatar
Looks nice man One antenna that I always thought would look good on a tricked out SC is the newer style SL Mercedes cone shaped antenna. I couldn't find that great of a picture, but take a peek at it next time you see a new SL in person.
Old 08-18-08, 06:46 PM
  #32
felixsc300
felixsc300's Avatar
Very, very nice.
Old 08-19-08, 08:02 AM
  #33
818sc400
818sc400's Avatar
Originally Posted by nexus 4.0
the antenna i got from Ebay for $3.99, its for VW and BMW cars (2.5 Inches)
and i used a universal mount for the rest of the install, however u have to reuse the factory gromet.
your antenna look hot. where can i get a universal mount at and how much?
can someone post up a DIY, i have no clue on how to take it apart
Old 08-19-08, 10:07 AM
  #34
nexus 4.0
nexus 4.0's Avatar
Besides the antenna, you need a universal antenna mount. i bought mine from autozone for $20. it was the GM universal antenna, but you can use others. also, you have to use your factory gromet.
Old 08-19-08, 10:30 AM
  #35
VJZ
VJZ's Avatar
I bought one from my local CarQuest with attached audio specialty store.
It was made by Metra and was $23 delivered to the store
Old 08-19-08, 10:42 AM
  #36
P.R.S.22
P.R.S.22's Avatar
I'm looking at the Metra website and there are several different adapters. I have the S2K antenna so would I need the Honda adapter or the Lexus adapter??? Which one did you use and what antenna do you have???
Old 08-19-08, 07:05 PM
  #37
818sc400
818sc400's Avatar
what did you use as the base?
Old 08-19-08, 10:07 PM
  #38
FL1PP3D
FL1PP3D's Avatar
Originally Posted by P.R.S.22
I just got the S2K antenna from the Honda dealership for 27 bucks. Going to try and get it on the car tomorrow if I have time.
Wow, I bought one for my Celica for $12.
Old 08-19-08, 10:20 PM
  #39
blade80
blade80's Avatar
looks clean...
Old 08-21-08, 12:11 PM
  #40
nexus 4.0
nexus 4.0's Avatar
Alright guys, here is a very crude diagram of what the install of the antenna looked like when I did it.
Some fine points to think about is that you might have to modify the grommet to fit the tightening nut can fit just right. The aftermarket antenna from AutoZone works well, but you have to extend the ends of adjusting plate due to the size of the antenna hole on the SC. The size of the hole is the reason why it is best to use the factory grommet, since the aftermarket ones are too small or not angle right.
Anyway, if you have questions, post them and I will try to answer to the best of my knowledge.
antenna.pdf
Old 08-21-08, 01:06 PM
  #41
TheKevin
TheKevin's Avatar
so you used the stock sub-antenna?
Old 08-21-08, 01:35 PM
  #42
nexus 4.0
nexus 4.0's Avatar
Sub-antenna?
The only item that is reused, is the factory gromet. Everything else is from the aftermarket antenna: The antenna post, tightening post and adjusting plate are all one piece. the tightening nut screws down on to the tightening post and sandwiches the adjusting plate, body and gromet together.
Old 08-21-08, 02:39 PM
  #43
TheKevin
TheKevin's Avatar
the sub-antenna is the part that's in the trunk.
can you list the part # of the sub-antenna you bought.
Old 08-21-08, 02:44 PM
  #44
blacice83
blacice83's Avatar
Nice, work i wouldnt mind doing it to mine. I dont like the long ant. plus i know its on the line of not going up any more. Great Job!
Old 08-21-08, 03:30 PM
  #45
nexus 4.0
nexus 4.0's Avatar
i'll stop at Autozone tomorrow and get the part #'s
Quick Reply: Antenna Conversion
