Sound Quality of Bypass
Could anyone comment on the sound quality of an amp bypass in comparison to a stock Nak system on a 2G GS. The new system would be a Avic-D1 and a 2 ch amp that is only powering the sub (10" type r).
Since I am not putting in a 4 ch amp to power the speakers, I am worried that the output will significantly less than the stock. Any comments?
Thx in advance.
EDIT: Thanks, basketthis
Thx in advance.
Factory amps put out anywhere between 30-50w per channel. Aftermarket unit does the same because it's internally amplified. Don't worry. And if you just use the integration harness you will still be using your factory amp!
Stage3
09-03-08 09:55 PM
