Kenwood In-Dash install issue
I jsut finished installing a Kenwood DDX 712 in dash cd/dvd player in my 92 Lexus Sc300. The problem I am having is I am not getting any sound out of my rear speakers. Also, the fronts are working, but I get a low whine when the volume is low that matches the engine rev when the car is running. Any ideas?
Do you mean the rear speakers don't work or the factory sub doesn't work? The factory sub won't work when you put an aftermarket deck like that in there, but you should still have sound out of the other two rear speakers.
Unfortunately the speaker whine that matches the engine speed you hear is not going to go away unless you bypass the factory amp. If you search around, you can find which wires do what on the factory amp there in the passenger side trunk area, and bypass it all that way, but unless you do, you are always going to have that whine. Look around the forum a bit and you'll see that everyone w/ the SC3 or 4 that installs an aftermarket deck without bypassing the factory amp, has this problem.
Sorry.
Sorry.
The rear speakers dont work either. ANd they were working before I put in the new deck.
I got the amp bypass harness installed as well so I dont know why Im still getting the humming noise unless it is a bad harness or something. Might have to do with the rear speakers not working as well.
Gonna play with it some more tonight. Hopefully I dont have to rewire the whole thing
Talm12
GS - 1st Gen (1993-1997)
08-05-13 02:08 AM
-Samurai-
09-16-11 08:28 PM
OlschoolGs
06-09-06 05:33 AM
