Requesting a wire color identification on 2000 ES300 radio harness
Old 07-30-12, 09:05 PM
lo_dit
lo_dit's Avatar
just saw this, sorry i never got around to figuring this out. maybe someone else more electrically inclined could help you out.
Old 01-19-13, 05:14 PM
azcat90
azcat90's Avatar
I put a 99 es300 factory cd/cassette/radio into my 98 es300 - the 99 radio had a 20 pin plug and my 98 es300 has a 15 - I bought a female 15 pin harness to attach to the car and a 20 pin male harness to attach to the radio and I connected all the wires. Everything works except for the dimmer. radio lights stay on bright when i dimm all the other lights in the cabin. Can't see how to fix it.
Old 01-19-13, 06:45 PM
azcat90
azcat90's Avatar
Default Pulled out 20-5 shoved it into 20-12, spliced with 15-9
Figured it out from other posts - 20-5 was unused so I pulled it out and shoved it into 20-12 and then spliced it with 15-9. Worked... Dimmer = ill+/ill-...
Old 07-15-14, 12:57 PM
DreES300
DreES300's Avatar
Exclamation wire color identification on 97 es300 stereo
!!!!HELP!!!!!I need to know the color identification color diagram of my 97 es 300. I am hooking up an amp and sub to the factory radio. So I need to know the 4speaker wires, Acc for the remote wire and the ground wire
Old 11-28-19, 10:51 PM
DEUCEWHITE
DEUCEWHITE's Avatar
Default Not sure if this ever worked out I skimmed read it
I've been dealing with this problem since a person I know cut all the wires when I asked them to pop the wires out the connection harness 😂 was going to adjust them to match a harness I have. So I've eliminated the CD changer also. I am trying to install pioneer avh 4000 and use the system as it was though that is not going to happen I think.
Notes on it so far I've made sure there is plenty of errors Mine is a 1998 ES300
mrmarsh
09-11-22 11:25 AM
teezee1000
ES - 6th Gen (2013-2018)
02-20-20 06:49 PM
offandongu
12-24-18 07:47 AM
76mmturbo
SC- 1st Gen (1992-2000)
01-07-16 08:51 AM
damiendada
10-21-13 04:50 AM
Quick Reply: Requesting a wire color identification on 2000 ES300 radio harness
