replace Mark levinson set up with Aftermarket
ive had it with these mark levinson amps blowin...im on my 3rd amp
Tweeter says they can put a aftermarket head unit, keep the nav were its at and run a alpine amp that is 5 channels for all the speakers..
They even say the Mark Levinson speakers are reuseable..
im at wits end here...i will go nuts if another amp bits the dust these are just too expensive to keep buying..
what do you guys think?
Thanks!
Thanks!
Thanks!
Thanks!
There are a some different line outut converts that you can use to keep the stock radio in the car. Personaly I think it would look better with the stock radio as well. But the line output converters convert the speaker wire output to RCA output to be able to install an aftermarket amp to the stock speakers.
shawnberry
15
02-06-09 02:39 PM
