Keeping factory amp on 2GS
Old 09-13-08, 11:11 PM
lexusscturbo
lexusscturbo's Avatar
Default Keeping factory amp on 2GS
I have a 99 GS300 and was wondering if I install a a dual din monitor/touch screen navigation is there any way to keep the factory amp for the speakers? For the subwoofer its not a huge issue but I want to keep the factory speakers with the aftermarket HU.
The current HU in question is the 20D Eclipse
Old 09-14-08, 06:52 AM
ivory98es3
ivory98es3's Avatar
yes you can keep the factory amp. some will tell you to "bypass" it and splice into the factory speaker wires but then you will lose the oem sub. just make sure you get the correct wire harness that has rca pigtails to connect to your new HU. Also, do not use the factory ground through your wiring harness. Run a new ground to either kick panel (better factory grounds found there) or go straight to the battery. If you use the ground from the factory wiring harness, you will have noise; i.e. alternator whine.
I was successful in keeping my stock amp in my ES300 by doing this and didn't have any noise at all.
good luck
Old 09-14-08, 07:32 AM
lexusscturbo
Ahh *nod* thanks.
I searched but didn't have any luck in a DIY?
Any good displays under 4 bills?
the Eclipse 20D is right at around 400 or I could go with a used unit?
Old 09-14-08, 04:33 PM
ivory98es3
ivory98es3's Avatar
I'm currently runnin' an Alpine IVA-W205 (double din DVD unit). You can find these used for around the $400 range. The Eclipse should be fine, just a matter of options you want.....
Old 09-14-08, 07:42 PM
lexusscturbo
I was hoping to have Navigation too for under 450..
Old 09-17-08, 09:14 PM
lexusscturbo
Searched no luck?
Old 09-18-08, 09:26 AM
jtgs400
jtgs400's Avatar
IIRC there is no wiring harness for the 2gen gs. I think a few people said you can use a toyota one but that's just to get the headunit working. Easiest is to just go all aftermarket. You can keep the stock speakers if you want though.
Old 09-18-08, 10:11 PM
lexusscturbo
The stock speakers don't sound too good with an aftermarket headunit; they work best with its matched amp?
Old 09-19-08, 06:07 PM
basketthis
basketthis's Avatar
Best recommendation is to bypass the factory amp and go with aftermarket amp/sub in your particular situation. I would especially suggest this if there was in fact no harness available for your vehicle. GL!!!
Old 09-19-08, 08:14 PM
Percy
Moderator - Electronics Forum
Percy's Avatar
NOT TRUE AT ALL. Bolt on a pair of GOOD aftermarket speakers. You'll be surprised at the difference. The stock speakers have a very narrow range of audio reproduction - quite poor actually. Plus the sound stage is quite small. No depth, no real positive character.
The amp is fair at best and that goes for the electronics.
Old 09-20-08, 07:25 AM
lexusscturbo
I do have an aftermarket sub and amp. Wired to the factory HU (via a Hi/Lo Conv.) which was a PITA to do. :lol:
Old 09-20-08, 07:34 AM
lexusscturbo
-Ran the RCA wires under the center console and trans tunnel- pulling it under the carpet was a PITA... and then the power wire via the door sill to the trunk
Old 09-25-08, 09:09 AM
vrferrari
vrferrari's Avatar
So... was there a diffinitive answer on the original question ?
Can you keep the existing Lexus 2ndgen GS Pioneer amp/speaker combination and use an aftermarket radio harness to install a new head unit ?
Old 09-25-08, 02:00 PM
bg_281
bg_281's Avatar
I just installed my Alpine IVA-W200 on my 01 GS430 with Mark Levinson. We used the Metra harness 70-8113 and wired it up and the screen had power but there was no sound output.. we had to do a amp bypass... it wasnt that hard at all. The only thing is locating each wire from the factory amp but we looked it up online and it was a breeze. As far as the pioneer system I dont know if its different but thats how I had to do it with the mark levinson hope that helps.
P.S. - to do aftermarket audio on most factory amplified systems requires amp bypass...
Old 09-25-08, 09:05 PM
lexusscturbo
Originally Posted by louiegs400
yes it can be done,
go to a audio shop
they have to bypass the stock amp
they know what to do
Louie its not that hard to bypass the Amp. I've done it before on 3 cars. My friends SC300 was the biggest PITA but not a big issue.
Quick Reply: Keeping factory amp on 2GS
