Door Speaker Question?
Best 4" speakers to replace factory door speakers? price range in between 150-200 for a pair. please let me know your guys opions. probably wire up a seperate amp and remove factory one. thanks in advance.
I'm using Polk Audio 4" door speakers with what I believe is a built in 1" tweeter. They sound great. I paid about 150 dollars for two pairs, front and rear.
at $160 you can get:
MB Quart DKG 110 US
4" 70W 2-Way Car Speakers
or
for about $90
Infinity Kappa 42.9i
The polks mentioned before are pretty good but they are all coaxial speakers... I'd recommend spending the same and using some good components.. you will definitely appreciate the difference.
MB Quart DKG 110 US
or
for about $90
If I remember correctly that's what a resistor that's designed to block the bass signal from the amp to the speaker is called, it's cylindrical in shape with a wire coming out of each end. Small speakers are not designed or rated to receive and process amplified bass sound; the signal fries the speaker. I burned out two sets before I wised up...lol hey nowbody's perfect, lucky I got the other set for free...lol
Its kindof like having a highpass filter for your speakers. My IVA-W205 headunit has that feature so I have almost no bass going to the speakers and just to the sub, definitely should prolong the life of the speakers.
Passive devices like this are nice and cheap but a true active crossover works best. Whether it is built into the HU, built into the amp or and external model. With a passive model above, your amp is still straining to push the bass out. With an active model, the bass is filtered before the amp. You end up with a much cleaner signal.
-Robert
Also post my vote for the awesome MQ Quart German speakers with the crossover network. An amplifier with bypass filtering for the different frequencies should isolate the bass to one channel, right? Then you dont have to worry about sending the wrong frequency to your speakers.
If you really want to improve the sound, while you are at it and have the door panels off, put some type of sound barrier, on the doors, inside and outside - the area that is covered by the plastic door panel, and it will really improve the sound .
Been investigating this for weeks, now, digested tons of information, looked at a dozen websites of people that make these products, and right now, the best one to me is Cascade Audio out of Bend , Oregon. Their products are well engineered, do what they say they will do, and are way way lighter. In fact, in some instances, they recommend you only put 1 layer down, because that is all you will need. All or most of the other vendors want you to add multiple layers, and this will only add more weight to the car. It will work, but why do you want to spend more money for layers, and add weight, which will lower your mileage to a degree too.
Good luck with your project, let us know how it comes out! DanF
Rock-a-Lex
05-31-11 09:20 AM
