IS-250 w/Auto-Mate, excessive horn chirping
We just bought a 2006, used IS-250. It has 30k miles and is in beautiful shape. It came with "Auto Mate" which is an OEM add-on for additional security. We're not sure Auto Mate is causing the issue below, or if it is the standard security system. Issue: With the engine running, I push the ignition switch to turn off the engine. Here is the sequence/duration of horn beeps: -one short -pause -two short -pause -one extended (about 2-3 seconds) This must be an error/problem, since I see no way anyone would program a system to do that after a normal engine stop. I've read the small "Auto Mate" manual and it does not mention any beeping after ignition stop. I also looked through the regular Lexus manual and have found nothing related to this. Please help. Any clues will go towards solving this issue.
Thank you. Ed
Thank you. Ed
The Auto-Mate systems are nearly identical to the dealer-ripoff Karr systems. Sounds like you're in programming mode or there's a problem with the Auto-Mate brain which is really just a shock sensor and a rudimentary alarm.
DEI is tight-lipped about the programming mode since they feel only installers should have that info.
s4m222
10-30-09 10:15 PM
