92 SC 300 Install Begins (Version 2)
Old 05-11-09, 06:50 PM
  #76
SSmith
SSmith's Avatar
Door skin Dynamated.
Shane
Old 05-11-09, 06:51 PM
  #77
SSmith
SSmith's Avatar
Door with the Second Skin luxury liner on. No more rattles here.
Shane
Old 05-11-09, 06:53 PM
  #78
SSmith
SSmith's Avatar
Door skin back on. Yes this is a seventeen year old interior.
Shane
Old 05-11-09, 06:55 PM
  #79
SSmith
SSmith's Avatar
Trunk lid dynamated. Going to layer with luxury liner and then reinstall the factory panel.
Shane
Old 05-12-09, 07:02 PM
  #80
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
My mouth is still open from the first picture of this beautiful install. I also use to do car stereo installs when Audio Control and MB Quart was ****zel. I have to say this is extremely well done, and my hat is off to you. Keep the pictures coming if there is anything further coming after.
Old 05-15-09, 10:51 AM
  #81
branflan
branflan's Avatar
Nice install! Wrapping up my install with XR 6.5s front and back and a 10l5 ported in back. I'm tempted to take the plate off the backseat like you did. Have you listened too it with that off yet? - Brandon
Old 05-18-09, 11:33 PM
  #82
fliptrix
fliptrix's Avatar
Wow.. amazing work there! Wish I had the time a money to do all of this! Bet it sounds awesome!
Old 05-23-09, 07:35 PM
  #83
SSmith
SSmith's Avatar
Replaced my battery today. Did a ton of research on batteries before I bought this one. I looked at them all. Optima, Odyssey, Stinger, you name it. Most battereies being built out there are made by a company called Enersys. I spec'd a Stinger battery Model 1500 that I wanted but it was close to $300.00. Talked to the company and they make the Odyssey, Stinger and Diehard Platinum. All specs for all three battereies are the same along with there casing. I had a coupon for Sears so I got the Platinum for less than $180.00. I had to replace the factory battery tray and mounting hardware to mount it like I wanted. Stock mount wouldn't work. Cut the poles down to make everything look a lot nicer along with doing my Big 2. Most of my dimming went away but still have a little with everything on. May install a small battery in the trunk. Here's the pics.
Shane
Old 05-23-09, 07:37 PM
  #84
SSmith
SSmith's Avatar
Second pic. You can see some of the new loomed wiring and the 150 amp Stinger circuit breaker mounted to the factory fuse box cover.
Shane
Old 05-23-09, 07:38 PM
  #85
SSmith
SSmith's Avatar
Third pic. Circuit breaker along with two runs of 4 gauge attached running to the back.
Shane
Old 05-25-09, 09:16 AM
  #86
702SC400
702SC400's Avatar
Total ideas for my new stereo system to replace my factory, worn out system in my SC400. Excellent work!
Old 06-18-09, 01:10 PM
  #87
SSmith
SSmith's Avatar
Bumping this thread because there's just not a lot of install info for our cars.
Everything is kind of in limbo. I did install a Gentex rear view mirror I need to post pics of. It's hot as hell here in Texas right now so not a lot going on on the install.
Shane
Old 06-18-09, 02:21 PM
  #88
HellFish
HellFish's Avatar
my my, that is a gorgeous setup. i dont usually come into this forum, but im glad i did.
Old 06-18-09, 04:29 PM
  #89
ICONYQ
ICONYQ's Avatar
yes it is hot as hell in TX (Austin) right now. We are living in triple digits. I keep going out to the garage to work on the car and come back in after alittle bit.
again, nice nice install
Old 06-18-09, 05:02 PM
  #90
MainSource
MainSource's Avatar
How much modification was necessary to fit the door skins over the 6.5" mids? I have been looking at a set of 6.5" Rainbows, but the only installs that I've seen require the grill to be removed and the door hacked up.
Quick Reply: 92 SC 300 Install Begins (Version 2)
