Does this work as an Infinite Baffle Subwoofer?
http://www.clarion.com/us/en/product...385113501.html
Its specs:
# 600 Watts Maximum Music Power
# 300 Watts RMS
# Single 4 Ohm Heat Resistant Voice Coil
# Polypropylene Electronic Spun Aluminum Dust Cap
# Fiber Glass / Paper Cone Design
# Nitrile Butadiene Rubber High Excursion Surround
# Strontium Ferrite Magnets
# Hyper Extended Vented Pole Piece
# Spider Exhaust Technology (SET) Cooling
# Dual Gold Plated Terminal Blocks
# Linear Cotton Spider with Integrated Tinsel leads
# Custom Shallow Stamped Steel Powder Coated Chassis
Its specs:
# 300 Watts RMS
The "specs" you copied tell me nothing about how the sub will perform. I consider those more "features" and features mean very little. If you go to the link and download the manual, it will give you the Thiele/Small parameters. You want to look at the Qts (.578 which is great) and the xmax (5.25 which sucks).
Yes, this sub and all subs will work in an IB configuration. How well they work depends on their T/S parameters. This sub will go past its linear limits with only a few watts of power. I would not use this sub in any application.
-Robert
-Robert
tuterz
09-13-09 12:04 PM
sjpobox
06-14-07 06:51 AM
