SC400 Car Stereo Installation Kit ??
Old 02-27-02, 05:32 PM
is300lexusgirl
is300lexusgirl's Avatar
Default SC400 Car Stereo Installation Kit ??
IS THERE A Car Stereo Installation Kit FOR A 92-97 ??
IF SO WHERE CAN I PURCHASE THIS AT?? I NEED IT FOR MY DADS GIRLFRIENDS RADIO.. SHE IS BUYING A AFTERMARKET HEAD UNIT.. THANKS GUYS!
Old 02-27-02, 05:39 PM
rhart00
rhart00's Avatar
Nope... and a lot of car stereo places will try to tell you that Toyota wiring harnesses will work but they won't. You have to figure it out manually. It isn't really that hard.
Old 02-28-02, 07:28 AM
xBlkGs430x
xBlkGs430x's Avatar
i was looking into the same thing last week, i couldn't find anything, but i found a guy that is going to make the kit for me, he will be finished with it by monday, if you are intrested i could send you a picture of it and if you like i'll have him make you one, e-mail me at azmh_ott@yahoo.com and let me know if you want
Old 02-28-02, 08:29 AM
'S'Low Rider
'S'Low Rider's Avatar
Unhappy Japanese again!!
There are stereo kits available for the Toyota Soarer, with the 2din face plate and the cabling to plug into aftermarket units.
The usual problems, finding anyone in Japan who will ship them worldwide and then checking that the harness matches up to USDM SC's......
Why is life so difficult
Old 04-26-08, 10:02 AM
termin8or
termin8or's Avatar
Old post, same problem. Where can I get a kit that will work? I can get the wiring done but I really would like to know that I have the correct mounting before I pull it all apart.
Old 04-26-08, 10:09 AM
SC40095
SC40095's Avatar
Circuit City told me they have the wiring harness and a dash kit because I don't have a radio at all. Just have to wait to get it done since the previous owner cut some wires to bypass the factory amp. Pretty much a hack job but I was told that the car used to belong to a car stereo installer. He must do ****ty work.
Old 04-26-08, 11:26 AM
Ali SC3
Ali SC3's Avatar
that is not a hack job, the factory amp sucks.
and if they made proper harnesses, you wouldnt have to cut them.
the reality is, is its much faster and the same if you have the ability to
match like colors.
Old 04-26-08, 03:18 PM
Ac93sc
Ac93sc's Avatar
Does anyone know where can i get this???????????????
thank you!!!
Old 04-26-08, 03:27 PM
BigManne
BigManne's Avatar
Circuit does not carry a plug and play harness or a mounting kit. they should be able to come up with something that will work. i work at a circuit city so i know. you will need the factory iso mounts that are screwed to the side of the factory radio. it will make the install easier if you can find some. Custom is the only way a kit can be made for it. factory is 2.5 din.
Old 04-26-08, 10:16 PM
blackops
blackops's Avatar
It's wiring 101 for anyone with radio knowledge to get an aftermarket radio working on the factory sound system.
Old 04-28-08, 12:04 AM
BigManne
BigManne's Avatar
as long as you know where the factory amp is and what wires are what.
Old 04-28-08, 08:15 AM
88supramki
88supramki's Avatar
amp is in the trunk on the passenger side under the carpet of the trunk
Old 04-27-09, 05:07 PM
o_mtz16
o_mtz16's Avatar
Now its my turn to have the same problem how do u guys did it?
Old 04-28-09, 02:27 PM
6SOARER
6SOARER's Avatar
I found this kit online but Im not sure if it'll work...
http://www.installer.com/item/displa...php?it=70-8112
Old 04-30-09, 08:13 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
I just replaced my Nakamichi head unit with another one.. Simply said, you will have to make brackets for the radio to work on the stock mounting plate inside the car. The plate is what secures the front trim around the radio, ashtray, and cup holder.
I rewired all of the wires behind this. I cut the factory plugs and tested each one to find the 12 volt constant, remote and ground. I then ran all new speaker wire, along with 2 sets of RCA's to the rear, along the right side, through the rear seat hole.. This hole is behind the rear upper portion of the seat. It will have to be completely removed. Once I ran the wiring to the rear, I left 3 feet slack in the wire for plenty of play.
You can buy this wire at any radio place, this is one solid piece of plastic, that holds 8 wires on the inside, it keeps it all together, so basically you are running 8 wires at one time. Dont forget to run your RCA's along with it, if you are using amp/s.
Got to Lextreme, to get the audio link for the whole wiring. If you are replacing all the speakers, the front are 4 inch, the rear is 5 1/4, and the sub is a 10.. Make sure to measure the depth of the new sub, due to the gas tank being real close. Heres the link. If you choose to use a aftermarket amp, then trash the amp, or sell it.
http://www.lextreme.com/misc.html
Make sure you ground everything properly and take your time.. If you need some help, PM me! I can send some pix or give further instructions on this.
Quick Reply: SC400 Car Stereo Installation Kit ??
