Stock sub removal yes I searched
Found nothing , you guys have said just remove the cover and the 4 screws and pull up.. I have given it ALL my might and it wont effing budge. I even have hammered it a bit from the bottom up... What am I missing?
remove your rear bottom seats.. remove 2 #12 nuts behind each headrest, remove a couple of #12 and #14 bolts under the rear back rests.. remove 2 clips holding down the rear deck.. remove 2 pillar panels on each side of the rear deck.. remove black covering and a couple of bolts should be holding down the stock subwoofer.. there's a thread on here about this
he is driving a sc3/4 there is not 12mm behind the headrest
Pop the rear seat cushion out.
3 12mm hold the rear back cushion in place. pull that up and remove
You can pull out the rear deck without taking off the cpillars, but u will have to bend it. it is recomended that you remove the b/cpillar along with the seat belt so you dont damage the rear deck but it is 100% doable without it, just be careful. depeding on if you have 3rd brake light on thr rear deck you will have to disconnect the wiring and remove it. after there should be some 10mm that hold the rear subcover and subwoofer down. unbolt, disconnect and remove.
AirForceGS
GS - 1st Gen (1993-1997)
10-25-07 03:33 AM
