Fosgate Amp
I'm planning to get an amplifier from Rockford Fosgate. Which one should I get?
This: http://www.crutchfield.com/p_575P200...3&tp=115&avf=N
Or this: http://www.crutchfield.com/p_575P300...3&tp=115&avf=N
Which one would run cooler and would give out clean sound? I'm planning to mount the amp in the back of my trunk. Would that be okay? Is that going to make the amp hot? Please help out. Thanks.
2003 GS 430 ML Stock
You don't want to put that much more power to your stock sub. Like said before it would not sound right, too much is not always best. Also forget crotchfield....they are over priced.
The P200-2 will be optimized in a 4 ohm mono bridged configuration while the P300-1 will be optimized at a 2 ohm mono .
You would do well to place a small molded enclosure up there with an aftermarket 10" in there if you are concerned about space. A good shop can fab something up for you that will work well. As to the price, I won't even speculate. I know that if I were doing it, you'd be looking to spend at least $500 for the labor and materials due to the fact that it's a tight fit and each one will need to be completely custom engineered.
If your heart is set on running an amplified (well, more amplified
Big Mack
