Eclipse AVN5500 + 4 more tv's wiring question
Keeper of the light
I just bought an IS300 with 4 tv's and an Eclipse 5500 in it. The tv's aren't working so I am gutting the car and re-wiring it. Can you tell me what to do with the parking and reverse wires on the TV's please?
These are just generic tv's so they aren't too complicated, but I don't know much about these setups. Also, if I need it as well..... I need to know how to bypass the dvd while car is in motion thing as well (perfectly legal, read on). I have to wire the rear tv's for my passengers, but I'm probably just going to remove the front one's for some stock visors. They are kind of annoying. I just got the car a few hours ago.
Here's a pic of the set up for reference.![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
![](http://i32.photobucket.com/albums/d5/audiogodz1/IMG_9818copy.jpg)
![Post](https://www.clublexus.com/forums/images/icons/icon1.gif)
If it's using the video out on the Eclipse to feed a splitter, you shouldn't need to override the DVD lock. It will play only to the vid out.
As for the parking/reverse wires, not sure what brand it is and that may help. If there isn't a camera for backing up, there should be no need to hook it up to anything.
Big Mack
Big Mack
Keeper of the light
Thanks. ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
I have everything tonight after spending the day in the car working on it, but I still need to find the Vehicle Speed Pulse Signal wire on the IS300 so I can hook up the navi.... any clues guys?
i can get you the wiring diagram from work and post it up what year is the is. on the avn's i dont believe you need to do a bypass of anysort besides ground the ebrake wire. sometimes you need to put a toggle switch on it, depending on the model. Some indashes if they sense a ground signal while the indash is turning on it will know you are trying to trick the system, if you put a toggle switch on it hooked up to ground and flick the switch after the indash loads it will simulate a ebrake type signal being sent. if you need some more info or tech stuff we can take this to pm's if you want
also for some reason if you cant get vid to work thru dvd/av1/av2 input you can use rear camera input hooked up to an ipod/external video source and have a switched on the rev. signal input wire goign to 12v and it will simulate a rear camera input.
Keeper of the light
Thanks guys
, I've been inside the car for 3 days re-wiring it and doing everything I needed to do to get it all correct. I just need to figure out what wire on the IS300 to hook the purple/white wire from the AVN. That's the speed wire for the navi.
(2002)
(2002)
![](http://i32.photobucket.com/albums/d5/audiogodz1/IS300/IMG_9875copy.jpg)
2002 Lexus IS 300
Remote Start, Security, Keyless Entry, Accessories
Item Wire Color Polarity Wire Location
12 Volts white & white/red + ignition harness
Second 12 Volts
Starter black/white + ignition harness
Second Starter
Ignition black/red + ignition harness
Second Ignition blue/red + ignition harness
Third Ignition
Accessory red + ignition harness
Second Accessory
Third Accessory
Keysense black/yellow - ignition harness
Data Bus grn/blk (data), purple (clock), pink/blk (synchro) data Immobilizer Module
Can Bus High N/A
Can Bus Low N/A
Can Bus Sw yellow/red (door lock data) data L side of driv fuse box, 12 pin plug
Power Lock see Tech Doc 1070
Power Unlock
Lock Motor green/yellow body ECU
Driver Unlock Motor blue/black body ECU
Passenger Unlock Motor red/white body ECU
Parking Lights (-) red headlight switch
Parking Lights (+) green driver kick, harness to rear
Hazards
Turn Signal (Left)
Turn Signal (Right)
Headlight red/blue - headlight switch
AutoLights
Reverse Light red/black + driver fuse box, bottom, 13 pin plug
Left Front Door Trigger - body ECU
Right Front Door Trigger
Left Rear Door Trigger
Right Rear Door Trigger
Remote Start, Security, Keyless Entry, Accessories (Continued)
Dome Supervision use door trigger
Trunk/Hatch Pin red/yellow - driver kick, harness to rear
Rear Glass Pin
Hood Pin blue - alarm module
Trunk/Hatch Release blue/white 5wi body ECU
Trunk Release Motor
Fuel Door Release
Power Sliding Door (Left)
Power Sliding Door (Right)
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock use key sense wire
Trunk Alarm Shunt
Tachometer black igniter
Wait to Start
Neutral Safety
Clutch Pedal
Fuel Pump
Rear Defroster
Mirror Defroster
Left Front Heated Seat
Right Front Heated Seat
Speed Sense red/yellow abs and traction ECU
Brake Wire green/white + brake pedal switch
Parking Brake
Horn Trigger green/white - steering column
Wipers blu/blk(L),blu/red(H + steering column
Left Front Window (Up/Down) red - green A driver window switch
Right Front Window (Up/Down) red - green A RF window switch
Left Rear Window (Up/Down) red - green A LR window switch
Right Rear Window (Up/Down) red - green A RR window switch
Sun Roof (Open/Close) not recommended
Sun Roof (Limit/Close)
Memory Seat 1
Memory Seat 2
Memory Seat 3
Audio
Radio 12V blue/yellow + radio
Radio Ground brown - radio
Radio Ignition gray + radio
Radio Illumination green + radio
Factory Amp Turn-on
Power Antenna
Left Front Speaker (+/-) pink - purple amplifier
Right Front Speaker (+/-) lt. green - blue amplifier
Left Rear Speaker (+/-) black - yellow amplifier
Right Rear Speaker (+/-) red - white amplifier
Center Channel (+/-)
Subwoofer (+/-)
Aux. Audio Input Left (+/-)
Aux. Audio Input Right (+/-)
RSE Video (+/-)
RSE Audio Left (+/-)
RSE Audio Right (+/-)
Satellite Radio 12 Volts
Satellite Radio Ground
Satellite Radio Ignition
Satellite Radio Antenna
Satellite Audio Left (+/-)
Satellite Audio Right (+/-)
What Fits
Item Size Depth Location
Headunit
Left Front Speaker
Left Front Tweeter
Right Front Speaker
Right Front Tweeter
Left Rear Speaker
Left Rear Tweeter
Right Rear Speaker
Right Rear Tweeter
Center Channel
Subwoofer
Left Front Headrest
Right Front Headrest
Left Rear Headrest
Right Rear Headrest
Satellite Radio Tuner
Wiring Notes: Keysense
Notes:
Using the status output wire from the remote start to trigger this wire will disarm the factory alarm without unlocking the doors.
Wiring Notes: Data Bus
Notes:
The Immobilizer Module is around the ignition key switch. The immobilizer ignition wire is black/red and the ground reference wire is white/black.
Wiring Notes: Lock Motor
Notes:
The body ECU is attach to the top of the fusebox.
Wiring Notes: Driver Unlock Motor
Notes:
Wiring Notes: Passenger Unlock Motor
Notes:
Wiring Notes: Left Front Door Trigger
Notes:
The body ECU is attach to the top of the fusebox. The driver door trigger is red/green, front passenger door is red/black, rear doors is red/blue.
Wiring Notes: Hood Pin
Notes:
The alarm module is above the driver kick panel.
Wiring Notes: Trunk/Hatch Release
Notes:
Wiring Notes: Tachometer
Notes:
The igniter is on the driver side strut tower.
Wiring Notes: Speed Sense
Notes:
The ABS and traction ECU is above the driver kick panel.
Wiring Notes: Left Front Speaker (+/-)
Notes:
The amplifier is above the passenger kick panel. The left rear woofer wires are black/white - yellow/red. The right rear woofer wires are red/white - white/blue.
Wiring Notes: Right Front Speaker (+/-)
Notes:
Wiring Notes: Left Rear Speaker (+/-)
Notes:
Wiring Notes: Right Rear Speaker (+/-)
Notes:
sorry trying to post from work is epic fail this is a diagram from directechs, if you couldnt find it in the posting its.
Second 12 Volts
Second Starter
Third Ignition
Second Accessory
Third Accessory
Can Bus High N/A
Can Bus Low N/A
Power Unlock
Hazards
Turn Signal (Left)
Turn Signal (Right)
AutoLights
Rear Glass Pin
Trunk Release Motor
Fuel Door Release
Trunk Alarm Shunt
Wait to Start
Neutral Safety
Clutch Pedal
Fuel Pump
Rear Defroster
Mirror Defroster
Parking Brake
Memory Seat 1
Memory Seat 2
Memory Seat 3
Audio
Factory Amp Turn-on
Power Antenna
Subwoofer (+/-)
RSE Video (+/-)
What Fits
Headunit
Left Front Speaker
Left Front Tweeter
Right Front Speaker
Right Front Tweeter
Left Rear Speaker
Left Rear Tweeter
Right Rear Speaker
Right Rear Tweeter
Center Channel
Subwoofer
Left Front Headrest
Left Rear Headrest
Right Rear Headrest
Notes:
Notes:
Notes:
Notes:
Notes:
Notes:
Notes:
Notes:
Notes:
Notes:
Notes:
Notes:
Notes:
Notes:
"The ABS and traction ECU is above the driver kick panel." u should be able to meter the wire if you are that worried about grabbing the wrong wire. the indash is not sending a signal out to the wire just recieving and you could always put a diode on it. you can meter it by jacking up the rear put it on stands ptut he car in low/first and u can meter the wire. i forgot if speedo is on ac or dc voltage tho.
Big Mack
PS: what are you using to display the pic? I like the layout of that.
hahah epic fail, umm lemme see if i can get a pinout. worst case jack up the rear put the rear on stands and put it in 1st and let the wheels roll and u should get a reading on ur meter. but ya strip back, poke a hole thru the strands of wire. put wire thru wrap aroud tape/ziptie to relieve stress or u can solder and tape
Keeper of the light
Looking at that pic, it should be the one in the upper RH corner, IIRC. Strip a bit back (not cut) and poke the wire through. If it works like it should, make a proper connection. If not, wrap the wire back up and do the upper LH corner. I'm pretty sure it's the RH one, though.
Big Mack
Big Mack
it's a Mac, Mack.
