Good deal?
Good deal?
I want to upgrade the sound in my car a LOT, but for cheap. So I started perusing Craigslist and found 6.5" Polk db component speakers for $50 cash. Everything works like new. Its only $50, but if these don't fit or suck in a 2GS4, it wasted $50.
Thoughts?
Thoughts?
Ahhh yes they wont fit....but you can make them fit. Buy the ebay adapter plates. They work and are only bout $20. Not the highest qualtiy but def. get the job done. Pkus your already upgrading from a 4" to a 6.5". Not a bad start, and nothing wrong with Polk either.
This is actually for 4 mid speakers, 4 crossovers, and 2 tweeters (he's 2 tweeters short of two sets of speakers).
We'll in that case it sounds like you got a great deal. Plywood would work but I'd go buy a small sheet of MDF and do it yourself. Plywood is cheap and not very good for stereo installs.
Used these adapters on plenty of cars using the same method and always been happy with the results. Cuts down on the time, too.
Big Mack
PS: Yes, that's a good deal at $50.
Sweet--that's what I'm gonna do. I'll look into those Metra plates--thanks! If not, I'll defintely use MDF vs. plywood.
Because I'm two tweeters short of two sets of components, I think I'm going to use the stock tweeters in the new setup. Question, though: wouldn't I get better imaging if I removed the stock speakers from the rear doors and installed the new speakers in the back deck on either side of the sub instead of back into the rear doors? Also easier to wire to an amp, adds a couple more pounds over my drive wheels, etc. I unno, just a thought.
Big Mack
Here's what I have on my limited budget:
Front: Polk db 6500 6.5" components
Rear: Polk db 6500 6.5" components (but with MB Quart tweeters--a frankenstein set)
Speaker amp: not sure if I want to add one yet...
Subwoofer: 10" Infinity Kappa Perfect
Subwoofer amp: MTX 250W @ 2 ohms, 125W at 4 ohms
Any advice is appreciated... I have yet to figure out how the wiring's gonna work yet...(ie. keep stock amp for inside speakers, where to tap for what, etc) Much CL searching ahead of me.
Xeeeeeem
05-11-06 09:48 PM
