Anyone know why when locking/unlock the remote all doors lock but the drivers door?
Does anybody know why when you lock/unlock the car with the remote, all the other doors unlock/lock but the driver? Need help on fixing this problem...
Inside the door itself. It connects to the door handle. Look at the door handle and lock cables...it will lead to the actuator. The actuator has 2 connectors connected to it. It's not too bad to replace. If you're going to rebuild it (gotta crack open the case), then be careful not to pull out the gears otherwise the internal spring is gonna pop out. It's kind of a pain to get it back in.
First time will take you maybe 1-2 hours depending on how well you know your thing. I've done enough that I can get it down in may be 45 for the fronts and 30 min for the rear
First time will take you maybe 1-2 hours depending on how well you know your thing. I've done enough that I can get it down in may be 45 for the fronts and 30 min for the rear![Stick Out Tongue](https://www.clublexus.com/forums/images/smilies/tongue.gif)
if your located in socal... :]
lv6l
04-05-10 11:35 PM
