Vaistech - new VML Feedback!!!!
#31
Even on 2010 Lexus factory USB input adapter use analog connection.
#32
Edit: I went back and did find the R+ R- L+ L- analog inputs to the amp on the schematic.
#33
"R+ R- L+ L- analog inputs to the amp" - balanced audio.
"The advantage of this connection is that when used for long distances the noise (interference) is not only canceled out by the alternating voltages but because its a higher signal voltage it can travel much longer distances without interference and without a booster."
Read more: Understanding Unbalanced vs Balanced audio signals, and the difference - Home Theater Forum and Systems - HomeTheaterShack.com
#34
I'm familiar with balanced audio - my home setup runs full balanced, but true balanced connections require positive, neutral and separate ground for each channel which isn't shown in the schematic I found - diagram in the repair manual could be confusing or incomplete as it tries to represent both ML and non ML setups.
#35
Rosson3ri
02-02-16 11:49 PM
vbb
01-24-13 12:53 PM
lexboi250
02-24-12 06:13 AM
